I just got my Note 3 the other day and have the same issue. Verizon, Best Buy, and the Samsung rep at Best Buy (even after calling tech support at Samsung) cannot solve it. Being hearing-impaired, the vibration feature is important to me.
In the "Messages" settings, under "More", the "Vibrate" is checked (after turning the volume up ever so slightly so the vibrate icon is also on the speaker icon with the slash through it.
Then under the device settings, "Sound", "Vibrations", it is set for "Basic Call" or any of the others. Tried the custom settings as well. (When selecting them, the "test" vibrations are quite intense.) The "Vibration Intensity" setting for "Incoming Call" and "Notification" are both turned up all the way.
Yet, when receiving a text message, I still only get the two short bursts of vibration which is not much help to me. The Samsung rep had a S3 (I think) with identical commands and setup features, and his vibration DOES work as advertised, but cannot replicate that on my Note 3. None of the vibration patterns (including the custom ones I created) under "Sound"-"Vibrations" work at all.
Samsung in Texas says that even though it is on the settings menu, the Note 3 does not have the ability to change the notification vibrations!
What to do?????
Thanks!
