Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By celljunkie
    Question Will the Otterbox for the Note 3 fit my charging cable?
    Does anyone have the measurements of the Micro USB 3.0 opening for a Note 3 otterbox? I want to make sure that my charging cable will fit through the opening on the otterbox.
    All I need is the length and width of the opening for the otterbox. If the size is bigger than my cable connector, i will most likely buy one.
    Thanks!
  2. #2
    celljunkie's Avatar
    Posts
    Global Posts
    54 Global Posts
    Default Re: Will the Otterbox for the Note 3 fit my charging cable?
    I have the Defender, I hope this helps you!
    Dog5000 likes this.
  3. #3
    Dog5000's Avatar
    Posts
    Global Posts
    958 Global Posts
    I have the Commuter case. The OEM issue cable works just fine, as does one from my old Note 2, and several other older Blackberry issued cables. No problems for me with any of those.
  4. #4
    Yes, it works fine. My charging cable fits the otterbox commuter case perfectly. I just received mine from yesterday.
  1. Samsung GS4 charging help?
    By Nick Iudiciani in forum Samsung Galaxy S4
    Last Post: 12-19-2013, 12:07 PM
B
