Results 1 to 7 of 7
    Default NFC using S View Cover
    Just wanna ask. Does NFC work with S View cover? Mine is authentic with the 2 gold metal at the back. (?) I tried it with my friend's Note 2 and it didn't work. I was hoping I could transfer a MS Word document to her phone thru NFC but it didn't 😟
  2. #2
    Default Re: NFC using S View Cover
    I didn't have any issues w/ NFC while using my S View but then again I was only transferring apps between 2 different owners who both have a Note 3 and one w/ an S4. I'm assuming you have S beam on too while transferring (I was told by a Samsung rep both needs to be on). Maybe the document wasn't compatible w/ her Note 2? Try a test and see if the document will transfer by using it w/ just your original backing
  3. #3
    Nfc radio antenna on note 2 is in the cover,, on the note 3 it's in the battery. The s veiw cover does not have an nfc antenna on it,, I am pretty sure those metal things are for inductive charging so if a s veiw cover is on a note 2 nfc will not work. That is the problem,, that is why nfc is not working on your friends note 2 with a s veiw cover on.
    THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
    love my evo.
  4. #4
    Quote Originally Posted by zmann View Post
    The two metal prongs are to activate the S view feature.
  5. #5
    Quote Originally Posted by sux2bu View Post
    Yea,, good catch. I just received mine 10 mins ago and came here to edit my comment.. Now that I see it and know how it works.. Thanks.
    love my evo.
  6. #6
    Would love the answer as well. I do not have another device to test the NFC with but I do have the S View and love it. Would be good to know if the NFC will work if I ever have the opportunity to use it.
  7. #7
    Yes, nfc works fine with my s veiw cover on. There is no reason why it would not. As said earlier the NFC antenna on the note 3 is in the battery, not the cover so s veiw case would have no effect on nfc in the note 3
    love my evo.
  1. S4 Flip Cover
    By joe_m_p in forum Samsung Galaxy S4 Accessories
    Last Post: 12-27-2013, 10:15 AM
  2. Disable autolock by cover in nexus 7
    By buiducthang in forum Android 4.4 KitKat
    Last Post: 12-22-2013, 07:30 AM
  3. Has anyone used any of these Logitech Keyboards? (Mac enhanced)
    By SpookDroid in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 12-21-2013, 01:47 AM
  4. Replies: 5
    Last Post: 12-19-2013, 11:39 PM
  5. Using LTE and voice on Verizon note 3 on tmobile
    By dpham00 in forum Samsung Galaxy Note 3
    Last Post: 12-19-2013, 10:02 PM
B
