Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Jean Marc Bejjani
    Default Galaxy Note 3 wifi issue
    Hello everyone. I bought my gn3 3 months ago and since then l have had issues with the wifi. It's not a very big deal and it's viable but enoying. Sometimes randomly when i am connected to my wifi it disconnect and my phone ask me to sign in. All i have to do to solve it is to click on sign in in the notification bar then click on my wifi network then click on sign in and it reconnect. The problem is that when I download things at night, and I sleep it disconnect and my download stops. Can anyone help me solving this issue? Thanks.
    yyue likes this.
  2. #2
    Default Re: Galaxy Note 3 wifi issue
    Welcome to Android Central! Do you have your own wifi network with your own router, or are you in a condo or apartment complex that shares one central wifi network? If you have your own wifi network, it seems odd that you would get the sign-in notification--I usually see this if I'm connecting to a public network that has a login page or a page where you have to accept terms and conditions first before connecting.
    It's my own router no one uses it except me. And it doesn't ask me for conditions. It's my personal wifi router but i live in a country where connection is not really fast nor stable(lebanon) i get 2mb/s of download speed. I dont know if my problem come from my connection but every other device except my note 3 doesn't have this problem including my nexus 10. I don't know what is causing it.
  4. #4
    Oh, so it sounds like your router is periodically bumping only your N7 off the network, making you have to connect again. Have you tried rebooting the router? Also, review this guide and see if any of the tips help: [GUIDE] Troubleshooting Wi-Fi Connection Problems
    I have rebooted my router multiple times and i have uncheck a note 3 feature that makes the device switch from weak wifi connection to 3g (i had solve with this an other connection problem) but i don't know what makes this sign out. It's random and completely unpredictable so i don't know how to solve it. The result is i cant download at night (when the connection is free) and it upset me a lot. thanks to your help..
  6. #6
    What do you mean when you say that nighttime is when the connection is free? Do you mean that your home wifi service is metered during the day, but free of charge at night?
  7. #7
    A few more thoughts:
    1. Go to Settings>Wi-fi, tap Menu, then Advanced, and see if there is an option for "Keep Wi-Fi on during sleep." If you have that option, make sure it's set to Always.
    2. Do you know if your router is set up with a static IP address, or with a dynamic one (i.e., DHCP)? If you can find out, then also go to Settings>Wi-Fi, long-press your home wi-fi network, tap Modify Network, then tap the checkbox for Advanced Settings. Make sure the IP Settings matches whether you're using Static or DHCP (DHCP is most commonly used).
  8. Thread Author  Thread Author    #8
    In lebanon we have plans of data (i get 25gb/month) and we can use it during the day. At night(from 11pm to 6am) its free so we download as much as we can at these hours. I use dhcp and it matches and the wifi on during sleep is set as always.
  9. #9
    Do you have any idea if the disconnection is occurring at the transition time between free and metered wifi?
  10. Thread Author  Thread Author    #10
    No its totally random it can happen at either time and the time between 2 disconnection can vary a lot. From 5 min to 6 hours.
  11. #11
    I was having issues with my wifi not auto connecting, which could be your problem. A review I read had me change a setting and I have had no problems since.
    Settings
    Wifi
    menu key
    advanced
    place a check mark next to auto network switch. (turn this on)
    Hope that helps.
  1. Google sync issue - please help
    By djr7572 in forum Moto X
    Last Post: 03-25-2014, 03:00 AM
  2. Note 3 After market car stereo suggestions
    By waldo34 in forum Samsung Galaxy Note 3
    Last Post: 12-23-2013, 09:09 PM
  3. Replies: 3
    Last Post: 12-22-2013, 04:52 PM
  4. Note 3 and Note 8
    By tech_fan in forum Samsung Galaxy Note 3
    Last Post: 12-22-2013, 01:45 AM
  5. Att galaxy s4 on tmobile?
    By meow876 in forum AT&T Samsung Galaxy S4
    Last Post: 12-21-2013, 06:32 PM
B
