Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By FBA
    Default Ethernet Connection for Note 3
    Has anyone figured out how to connect a std Ethernet connection to their Note 3. Are hardware connection converters from std Ethernet male (looks like a telephone connector on steroids) connector to a mini USB connector on the Note 3? Is there an app or other to make this connection work via software to allow the Browsers to function? There are locations in the world with no WiFi and no 3g or 4g cell towers but Ethernet is avail.
  2. #2
    FBA
    FBA is offline
    FBA's Avatar
    Posts
    Global Posts
    2,261 Global Posts
    Default Re: Ethernet Connection for Note 3
    Can't be done today as the kernel likely has no support built in for that, but if you travel, you'd just need to buy a small WiFi router, or even easier, a WAP. Plug it into the existing ethernet cable and you're pretty much good to go right out of the box. Some units may need some configuration - as you're not going to use the router portion, but if you need WiFi connectivity with an Ethernet connection - it's a very simple and cheap solution!
    This device is cheap and easy to configure...and there are tons like this out there you can choose from. Since you're not tethered to a wired connection on your Note 3, I'd say this is a far better solution for you than what you were looking for.
    D-Link DIR-505 - Wireless router - 802.11b/g/n : Gaming | Dell Canada
    Converted lifetime BlackBerry user, now on Samsung Note 3...
    Bye bye Blackberry, forever.
    Dog5000 likes this.
  3. #3
    Interesting question. Link below discusses this for the Note 2. Looks like if drivers are not available in the OS, then not possible.
    [Q] Micro USB to Ethernet Port Adapter for Galaxy note 2 - xda-developers
  4. #4
    FBA
    FBA is offline
    FBA's Avatar
    Posts
    Global Posts
    2,261 Global Posts
    My answer would still be the same though - and at 50 bucks for a router that actually does the job better...seems like a no-brainer to me.
  1. Sprint Direct Connect now available for Note 3 / S4
    By k425 in forum Sprint Samsung Galaxy Note 3
    Last Post: 03-09-2014, 12:31 PM
  2. Sending pictures and videos on the note 3
    By SGEN3 in forum Samsung Galaxy Note 3
    Last Post: 01-02-2014, 03:39 PM
  3. "Leakage" on display after dropping my Note 3 (have picture)
    By Viggo Liljefors in forum Samsung Galaxy Note 3
    Last Post: 12-24-2013, 06:01 AM
  4. Replies: 2
    Last Post: 12-23-2013, 04:32 AM
  5. Sprint Direct Connect Available for Sprint GS4
    By k425 in forum Sprint Samsung Galaxy S4
    Last Post: 12-22-2013, 08:51 AM
