Results 1 to 11 of 11
    Default Note 3 decline in battery life
    Hello,
    When I first got my Note 3 it was easily getting 5 hour screen time with medium to heavy usage. Currently with the same usage I get 2 hours 30 mins of screen time. That's with about 75% brightness which hasn't changed since I set it when I first got the phone. I normally watch movies or shows, stream music and browse the Web. Data signal is always pretty strong as well.
    Any else notice a decline is battery performance?
  2. #2
    mspace81's Avatar
    Posts
    Global Posts
    71 Global Posts
    Default Re: Note 3 decline in battery life
    I say look at what apps you may have recently downloaded. There are some apps that even when not in use, runs in the background. I had to get rid of the instagram app after the update to instagram direct. It was the culprit in the decline of my battery. I now just use it on my tablet, until they fix the battery optimization for that app.
  3. #3
    Quote Originally Posted by Jnorton2724 View Post
    Hello,
    Post a screen shot of your battery stats so we can see what is going on? Are you using Google Now? Have you done a good ol' fashioned reboot!?
  4. #4
    Hello,
    Yes. We have two Note 3's in the household and both have noticed a drastic decline in battery in the last week. From well over a day of battery with heavy usage and 4 to 5 hours screen on time to just about 3 hours and barely making it to 11pm. Last night my phone was unplugged at 11 am and died on my computer desk at midnight for the first time since I owned it. Gsam reports nothing unusual that I can tell and I've double checked all my Google Now settings. Will post screen shot later.
  5. #5
    I agree with what others have said, about apps doing something different. My battery life has been awesome. Also, this is puzzling, we have the Note 3, which has this great feature of a "removable" battery, and it seems nobody using it.. I have two spare batteries, but NEVER get a chance to use them. I only used one just to see if they worked.
    Again, battery has been awesome on my Note 3.
  6. #6
    Quote Originally Posted by cehowardNote3 View Post
    LOL, you're right! I would be getting 4.5-5 hrs. screen on time with Bluetooth on, GPS, Google Now, and 4G on 100% of the time! I unplug at about 8 a.m. and by the time I plug it in at 10-11 p.m. I still have 30-50% left (generally I'll have between 2-3 hrs. screen on time at that point). This includes calls, texts, surfing the web, Gmail, snapping some pics,etc.
  7. #7
    I too noticed this change. Just ladt week my battery life was pretty good i could play, watch movies the whole day without worrying about the battery but now i noticed it to be draining faster than before, i didnt install any new apps or did an update. I cant find whats the problem. Any help guys? I already made a thread about this too i hope you could view it. Thanks!
  8. #8
    Screen time depends on the type of content you watch.Being an amoled display,you are going to get better battery life watching videos and movies than doing web surfing.Web pages contain a lot of white and this consumes a lot of power in amoled screens.
  9. #9
    FBA
    FBA is offline
    FBA's Avatar
    Posts
    Global Posts
    2,067 Global Posts
    I've noticed the same thing as well over the past few weeks. I think it has to do with some sort of updates the device may have downloaded for the OS. Battery life was better in the first month I got the device, maybe 6 weeks ago. Its not a huge difference, but a difference nevertheless. I have disabled a lot of the bloatware - but only what I felt was safe to disable after researching it. I had Touchdown installed, but found that was a real battery pig, so I got rid of that and just decided to use the crappy Samdung mail client for connection to my Exchange server. Also disabled the Gmail app and setup a Gmail account within the crappy Samdung mail client as well. Still, battery isn't as good as it was.
    Converted lifetime BlackBerry user, now on Samsung Note 3...
    Bye bye Blackberry, forever.
  10. #10
    Default
    On Oct 28th, I did my second battery calibration, it lasted (to 10%) 34 hrs with 8 hrs screen on, in a good cell signal environment (lot of green bars).
    Note 3 decline in battery life-2013-10-28-17-26-01.pngNote 3 decline in battery life-2013-10-28-17-26-13.pngNote 3 decline in battery life-2013-10-28-17-25-49.png
    On Nov 22th, I did my third battery calibration, it lasted 48 hrs (to 7 %) with 7.2 hrs screen on, in a poor cell signal environment (predominantly yellow bars).
    Note 3 decline in battery life-screenshots_2013-12-22-07-15-51.jpgNote 3 decline in battery life-screenshots_2013-12-22-07-16-21.jpgNote 3 decline in battery life-screenshots_2013-12-22-07-16-04.jpg
    Consider the standby time, cell condition, I cannot say the battery degraded in anyway.
    Try turning off data during standby, with time goes by, background activity with Internet connections may begin to creep up and eating more batteries.
    Also, try to take care of battery the right way. How to realy, really prolong your battery life.
    3200->Centro-->Pre-->Pre2-->HOX/N4-->GN3
    Palm T|X-->Transformer-->Galaxy Tab 7.7-->iconia w510
  11. #11
    I am also having battery drain in my Note 3. The cause is a bug in Android OS that prevents the Note 3 from deep sleeping. See also the thread:
    The only solution is to do a soft reset every time the problem starts. I also saw another forum in which they say the problem started after MJ7 update:
    I have tried many things now without rooting my Note 3 but nothing fixed the issue. Maybe only the kitkat update will fix this or will cause even more problems
  1. Kit Kat & LLama battery usage
    By djousma in forum Motorola Droid MAXX
    Last Post: 03-03-2014, 09:36 AM
  2. Problem in battery drain Note 3
    By ossamoha in forum Samsung Galaxy Note 3
    Last Post: 02-06-2014, 07:48 PM
  3. WI-FI using way too much battery
    By born2fly32 in forum HTC One
    Last Post: 12-23-2013, 01:40 PM
  4. missing the 'software update' button in settings (NOT on orange!)
    By maximdelaet in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-23-2013, 01:01 PM
  5. Note 2 txt msg protection
    By AERO993 in forum Verizon Galaxy Note 2
    Last Post: 12-23-2013, 12:43 PM
B
