Results 1 to 9 of 9
    Tyler Lietz's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Exclamation Galaxy Note 3 - CPU maxed out! help
    is there a way to see whats maxing out my cpu. I turned on nearby devices to dlna to my ps3 and my phone started getting hot. I turned nearby devices back off and rebooted and still hot. I checked my system monitor app and my cpu is maxed out. tried norton scan and it crashed. I clear cache and hard reset and still maxed and after 2 more minutes it went back down to normal. did a factory reset now to be safe
  2. #2
    SebasCvdB's Avatar
    Posts
    Global Posts
    528 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Rom
    Default Re: Galaxy Note 3 - CPU maxed out! help
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by SebasCvdB View Post
    I already found out how to check what was using my cpu. To bad I factory reset already
  4. #4
    Alain_A's Avatar
    Posts
    Global Posts
    4,942 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Tyler Lietz View Post
    How?
    Sent from my SM-N900W8 using AC Forums mobile app
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Alain_A View Post
    How?
    Well I have the app called system monitor which I pay for. Well the app cpu is in a stupid section. You'd think it's would be under cpu. It's under top apps. Like wtf, why would it be in there?
  6. #6
    Alain_A's Avatar
    Posts
    Global Posts
    4,942 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Lol got you
  7. #7
    stackberry369's Avatar
    Posts
    Global Posts
    2,522 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If one core is doing most of the work,what does this mean?
  8. #8
    nettech207's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    it usually means the app is not optimized for multiple cores
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Norton uses 4 cores at 2.3 ghz. They dont care how much their app uses battery. Most games I find run at 2 cores under power saver. 3 if power saver is off. Browser uses 4 at low clocks to keep power consumption perfect
  1. Samsung Galaxy Note 8.0 Screen Problem
    By Bigdogbob72 in forum Samsung Galaxy Note 8.0
    Last Post: 01-12-2017, 05:49 AM
  2. Watchon and Peel Smart App Forces Note 8.0 Shutdown
    By Scott Teale in forum Samsung Galaxy Note 8.0
    Last Post: 02-08-2014, 10:36 PM
  3. Just a quick Question about MicroSD for Note 2
    By dodong27 in forum AT&T Galaxy Note 2
    Last Post: 12-29-2013, 08:40 PM
  4. Help With Nova or Apex Launcher On Nexus
    By TheTeapot35 in forum General News & Discussion
    Last Post: 12-27-2013, 08:37 PM
  5. Help With Nova or Apex Launcher On Nexus 4
    By TheTeapot35 in forum Google Nexus 4
    Last Post: 12-26-2013, 02:08 PM
