Results 1 to 19 of 19
Like Tree3Likes
  • 1 Post By Gator352
  • 1 Post By ffejjj
  • 1 Post By FBA
    Default battey charging battery charging ..... what next !?!?
    I have note 3 sm-n900 ( 3g version)
    when i charge it and it reach 100% doesnt give full charged as other phones ??!
    it gives charging and for more than 2 hours still same message ,,,, charging charging ,,,, what next ? !!?! ?!
  2. #2
    Default Re: battey charging battery charging ..... what next !?!?
    What's happening is that your phone is charged to 100% and it's trickle charging keeping it charged at 100%. Your phone will say 100% charged but charging. It's normal so don't worry about it!
    Note 3 / Note 2 / S4 / Moto X / hTc ONE / LG G2
    but wat i no is that every phone gives that is full charged and stop charging ???
    Quote Originally Posted by Gator352 View Post
  4. #4
    Quote Originally Posted by ossamoha View Post
    Because Samsung phones (GS4 and Note 3) trickle charge after charging to 100% if left on. See, your phone uses background data to keep things up to date and that uses battery. So instead of charging to 100% and stop charging to run down the battery....it trickle charges once it reaches 100% to keep your phone charged at 100%. That's why your seeing 100% but it says charging. Nothing to worry about!
  5. #5
    But battery sign appears 100% charge remove the the charger to save power.
    Sent from my SM-N9005 using Tapatalk
    Using Tapatalk
  6. #6
    Quote Originally Posted by Amir View Post
    No need to remove charger. I mean you can if you wish, but I charge my phone overnight and leave it plugged in all night. Won't hurt phone and keeps phone at 100% when I leave for work in the morning.
    Amir likes this.
  7. #7
    I've seen this debate going in several areas now about weather or not to leave your phone on the charger after fully charged. I'd just like to add
    My evo LTE I bought on release so it's getting older. It doesn't get as much attention now that I have my One so it spends a lot of time sitting on the charger. Well yesterday I used it because I'm having troubles with my One and I got 4.5hrs screen on time and plugged in with 20% remaining battery.
    I leave all my phone charging unless I'm using them and have never had any ill effects
    Sent from my HTCONE using AC Forums mobile app
    Owner of a replacement Htc One... Till something better comes along
    Ambassador
    Gator352 likes this.
  8. #8
    Did it actually say 100%?
    @T-Mobile GN3
    3200->Centro-->Pre-->Pre2-->HOX/N4-->GN3
    Palm T|X-->Transformer-->Galaxy Tab 7.7-->iconia w510
  9. #9
    Quote Originally Posted by clevin View Post
    @T-Mobile GN3
    As I said. Sign appears that battery is fully charged and u can unplug the charger to save power.
    Using Tapatalk
  10. Thread Author  Thread Author    #10
    for me it is 100% but continues to say charging ,,, no msg to remove charger and fully charged
    @T-Mobile GN3
  11. #11
    FBA
    FBA is offline
    FBA's Avatar
    Posts
    Global Posts
    2,067 Global Posts
    When I reach 100%, it tells me to unplug the charger. It has always done this since day one.
    Sent from my SM-N900W8 using AC Forums mobile app
    Converted lifetime BlackBerry user, now on Samsung Note 3...
    Bye bye Blackberry, forever.
  12. #12
    Then there must be problem. U should receive notification to unplug charger.
    Using Tapatalk
  13. Thread Author  Thread Author    #13
    anybody can help with this problem ???
  14. #14
    I have never seen a message about unplugging the charger. Thought that was odd at first - then I bought 2 x try batteries (not Samsung) and have since forgotten about it. With this post I am back to wonder why. Maybe because the batteries are after-market?
    Sent from my SAMSUNG-SM-N900A using Tapatalk
  15. #15
    Just ignore the message. Mine say to unplug charger as well....it's telling you that it's 100% charged and you can unplug it....meaning...unplug and GO..to work, school, friends house, best buy, and etc. Just ignore it.
  16. #16
    FBA
    FBA is offline
    FBA's Avatar
    Posts
    Global Posts
    2,067 Global Posts
    He is saying he DOESN'T get a message to unplug.
    Thanked by:
    Amir
  17. #17
    Had mine OFF and charging all night long. Only thing I saw this AM was a battery icon with 100% on it. Means nothing probably I need to put it on charge while it is still powered up.
  18. #18
    The charge ran down to 90-something % this am and I plugged in the charger. On for hour or so. When I looked it was fully charged but no obvious message. I have a battery minder app so I supposed that could sur press the message.
  19. #19
    It's "Battery" by Jupiter Apps, ver 1.04.
  1. Droid Mini: Battery Life Since Kit Kat
    By wckesq in forum Motorola Droid Mini
    Last Post: 01-17-2014, 11:54 AM
  2. Just rooted...now what?
    By Rishi Bhatia in forum Nexus 5 Rooting, ROMs, & Hacks
    Last Post: 01-04-2014, 07:54 AM
  3. Replacement battery
    By Tvppy in forum Nexus 5 Accessories
    Last Post: 12-29-2013, 03:32 PM
  4. Charging Phone While Off Better?
    By win465 in forum Google Nexus 5
    Last Post: 12-29-2013, 10:42 AM
  5. How can I get my phone not to go in the battery save mode?
    By Taylork64 in forum Samsung Galaxy S4 Active
    Last Post: 12-29-2013, 06:30 AM
B
