Results 1 to 4 of 4
    Default Directing all audio through headphones?
    Hello, I was wondering if there is a way to direct all audio (notification s/ringtone/music/etc) through the headphones when those are plugged in and to function normally otherwise. Also is there a way to exclude the alarm from this setting?
    Basically, I want all sounds but the alarm to go through the headphones when they're plugged in.
    Either setting or application is fine!
    Thanks!
  2. #2
    Default Re: Directing all audio through headphones?
    Quote Originally Posted by barucch View Post
    Thanks!
    I believe should help you out!
    Thanks, it solves the problem with audio playing through both speakers and headphones! But the alarm still goes through headphonejack which is ok I guess
  4. #4
    I think if you get the paid version, you may be able to change that.
  1. Delete All Notifications?
    By Therealm80 in forum Samsung Galaxy Gear
    Last Post: 01-09-2014, 01:53 PM
  2. Headphone Issue on phone calls
    By coxley24 in forum Samsung Galaxy Note 2
    Last Post: 01-08-2014, 09:33 AM
  3. Whats .thumbdata file in thumbnail directory all about?
    By ganesh97 in forum General Help and How To
    Last Post: 01-01-2014, 11:18 PM
  4. Galaxy Note 3 - Bluetooth audio quality after update
    By polaraman in forum Samsung Galaxy Note 3
    Last Post: 12-31-2013, 01:38 AM
  5. S3 Android 4.3 not sending SMS and audio media to car anymore
    By Pstongelitho in forum Samsung Galaxy S3
    Last Post: 12-30-2013, 12:05 PM
B
