1. AndroidNote3's Avatar
    Guys my phones cpu is stuck at 2.2ghz and wont move, ive tried resetting the phone and ive unistalled the last app that I installed as it only happened when I put that app on my phone. Help please I dont want to have to fully wipe my phone.
    The phone just feel blazing fast its like its on steroids and the cpu stats app just shows all cores running at 2.2ghz
    Sent from my SM-N9005 using Tapatalk
    01-04-2014 07:28 PM
  2. AndroidNote3's Avatar
    Please guys its never done this until now
    01-04-2014 07:37 PM
  3. mspace81's Avatar
    You might have to just do a full reset...sorry 😔 hopefully someone can offer some advice
    01-04-2014 08:02 PM
  4. Nakrohtap's Avatar
    Hard to tell based on your information. Are you rooted? If you are, check your governor to see if it's set to performance.
    Sent from my SM-N900V using Tapatalk
    01-04-2014 09:09 PM
  5. wrich2005's Avatar
    Try clearing cache just for the heck of it.
    01-04-2014 10:14 PM
  6. AndroidNote3's Avatar
    Nope im not rooted, I also have this problem where if I restart my phone and when I try to unlock it using the pattern it will only highlight 3 dots and then it wont do anymore, its hard to explain
    01-05-2014 04:33 AM
  7. AndroidNote3's Avatar
    It happened when I needed to update MyMagazing, I had to click on 'Unknown sources' to allow it to install and then literally straight after my phone become usain bolt?
    01-05-2014 04:47 AM
  1. nexus newbie needs Bluetooth music help
    By Thurmojo in forum Google Nexus 5
    Last Post: 01-11-2014, 09:43 AM
  2. Help with transfering pictures
    By Stacy Barron in forum Google Nexus 4
    Last Post: 01-06-2014, 11:14 PM
  3. HELP!! Screen not working...
    By bbaulio in forum Samsung Galaxy S3
    Last Post: 01-06-2014, 01:14 AM
  4. need help using browser
    By retired05 in forum General Help and How To
    Last Post: 01-05-2014, 11:42 AM
  5. Nexus 5 - need help with windows vista.....
    By slik6996 in forum Nexus 5 Rooting, ROMs, & Hacks
    Last Post: 01-05-2014, 12:59 AM
