Results 1 to 25 of 25
Like Tree1Likes
  • 1 Post By shlomoreuven
    Default Note 3: ROM Stock/Battery
    My rom is Israeli Orange and I think it is too bulky
    Batteryis drainned quickly and fully redundant applications
    Looking for a clean stock recommendation altitude as much as possible and with an emphasis on battery life and speed of response
    Of course you will not take responsibility
    cooperxxx likes this.
  2. #2
    aspot72's Avatar
    Posts
    Global Posts
    198 Global Posts
    Default Re: ROM Stock/Battery
    Quote Originally Posted by shlomoreuven View Post
    Just flash generic EMEA ROM (get it from sammobile.com) with Odin 3.0.7 and then install MoreLocale2 to get hebrew language.
    Do hard reset before flashing and after flashing (just let the phone boot up, no need to set it up).
    Quote Originally Posted by aspot72 View Post
    HELLO MY FRIEND
    THANK YOU FOR THE ANSWER BUT WHAT IS MEAN EMEA ROM?
    I WANT ROM STOCK ONLY...
    I KNOW THE sammobile SITE
  4. #4
    aspot72's Avatar
    Posts
    Global Posts
    198 Global Posts
    HELLO MY FRIEND
    EMEA - Europe Middle East Area :-). Get the latest ROM and as mentioned above. Orange ROMs are filled with bloat ...
    (Turn of CAPS as it looks like you're "shouting).
    - thank you, ok
    What country or recommended version?
    I do not know the options so I ask
    Emphasis on application Minimum vague
  6. #6
    aspot72's Avatar
    Posts
    Global Posts
    198 Global Posts
    - thank you, ok
    For the fastest updates go with German version (DBT). I am using this version without any issues and always getting updates first... Other option would be Baltic countries(NEE)...
    I Have the 900 vesion
    i dont found this version
  8. #8
    aspot72's Avatar
    Posts
    Global Posts
    198 Global Posts
    Try Turkis version
    Attached Thumbnails Attached Thumbnails Note 3: ROM Stock/Battery-n9000.png
    Try Turkis version
    friend
    this is my model: SM-N900 Galaxy Note 3
  10. #10
    aspot72's Avatar
    Posts
    Global Posts
    198 Global Posts
    friend
    there you go : Firmwares | SamMobile | Page 3
  11. Thread Author  Thread Author    #11
    i know this option... this is the best rom for stability and battery life?
  12. #12
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    That's the stock ROM
  13. Thread Author  Thread Author    #13
    ok
    I installed the new stock rom
    And I still have the code of Orange CSC
    Is there a way to make MEGA WIPE before installing a new ROM? i did the factory reset only...
    Is this code change matter?
  14. #14
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    ok
    Full wipe would have to be with TWRP or CWM. Then you do an advanced wipe, and hit system, data, cache, and dalvik cache
  15. Thread Author  Thread Author    #15
    Hello Friends
    It is simply a catastrophe!!!
    Android OS eating battery
    What can you do???
  16. #16
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Download an app called Wakelock detector. It should tell you what's keeping the phone awake
  17. #17
    vsnlweb's Avatar
    Posts
    Global Posts
    357 Global Posts
    Hello Friends
    What can you do???
    What is your screen on time... Please post pics in English... It looks like your battery is lasting quite a while with 1 day 9 hrs... It could be that your OS is just using more power in relation to everything else...
    Sent from my SM-N900W8 using Tapatalk
  18. #18
    Screen is always highest on mine. Then Google services and then android OS. Not sure what from the OS is eating so much battery without google services being up there as well.
  19. #19
    aspot72's Avatar
    Posts
    Global Posts
    198 Global Posts
    Hello Friends
    What can you do???
    Do hard reset and set it up as fresh device - don't restore!
  20. Thread Author  Thread Author    #20
    Hello Friends
    I would like your help in generous
    I'm trying to solve the problem of this exhausting battery
    This time I solved the problem of deep sleep with an external application,
    But I find that when I use the device battery runs out quickly
    This means that if the screen is off then there is no depletion of the battery at all, about 1-2 percent per night
    But frustration is the speed of emptying the battery used
    I've included pictures your help:
    1. The screen was off the whole day
    2. You can see the battery discharges when the screen is turned on
    3. Google services, because what appears in 44 percent of the time is very low for about 5 minutes
    4. Screen time ...
  21. Thread Author  Thread Author    #21
    someone?
  22. Thread Author  Thread Author    #22
    do hard reset and set it up as fresh device - don't restore!
    how can i do hard reset?
  23. #23
    aspot72's Avatar
    Posts
    Global Posts
    198 Global Posts
    Settings-Storage-Reset device
    Sent from my XT1032 using Tapatalk
  24. Thread Author  Thread Author    #24
    im very sorry i dont find this option... only the sd card format
  25. #25
    aspot72's Avatar
    Posts
    Global Posts
    198 Global Posts
    Then it might be in the Security or Privacy.
  1. Time on battery...
    By mumfoau in forum General News & Discussion
    Last Post: 01-07-2014, 01:07 PM
  2. mobile networks/preferred network type??? * rom*
    By xyzlene in forum General Help and How To
    Last Post: 01-06-2014, 04:47 PM
  3. Battery charging, not charging, draining really fast.
    By smaffy in forum Samsung Galaxy S3
    Last Post: 01-06-2014, 01:05 AM
  4. HTC one battery draining too fast
    By dandrew68 in forum HTC One M7
    Last Post: 01-05-2014, 09:31 PM
  5. Strange battery behavior
    By henryfool3 in forum HTC One M7
    Last Post: 01-05-2014, 09:01 PM
