1. Floridadomer's Avatar
    I friend of mine just made the switch from iPhone to Android. She purchased a Note 3 (which is what I have) She came right to me because I am known for my love of Android. She is thrilled with Google Play, Google Music, Google Keep, Google Drive, etc etc. She kept saying, this is so much easier then iTunes!
    When she was at AT&T, they synced her contacts from her iPhone to the Note 3. They show up in the phone but aren't syncing to Google Contacts. I have gone under her Google account to make sure syncing contacts re checked. If anyone has any ideas, please let me know.
    01-06-2014 01:48 PM
  2. srkmagnus's Avatar
    Go to Settings > Accounts > Google Account of the device > Check Contacts then press menu and select "Sync Now". That should sync the contacts from the device to Google.
    From there, go to the Gmail account via desktop PC (or Web view on Mobile) and pull down the Gmail drop-down menu and select Contacts. Contacts should be sync'd there if successful. If there are ay errors, or the device is not syncing, please advise so we can further troubleshoot the issue.
    01-06-2014 02:29 PM
  3. TOBusa's Avatar
    I've done that, and it still does not sync
    01-17-2014 09:21 AM
  4. SpookDroid's Avatar
    Probably the contacts are set to be stored on the SIM card or Phone and not in Google. Try the "Merge Accounts" option and if that doesn't work, try importing the contacts to Google (Import from USB storage or from SIM card to Google).
    01-17-2014 12:16 PM
  5. Jelly Belly's Avatar
    I had the same problem.
    I went into contacts on my mac and exported them all a a vcard and imported into google contacts.
    My iphone was synched to my mac but if she has no mac then I have no suggestions.
    01-17-2014 02:50 PM
  1. Replies: 3
    Last Post: 02-01-2015, 06:52 PM
  2. Love my Note 3 !!! no issues I guess I got lucky :)
    By Rositha Maroney1 in forum AT&T Samsung Galaxy Note 3
    Last Post: 01-24-2014, 12:22 PM
  3. Contacts Missing????
    By tem#AC in forum AT&T Samsung Galaxy S4
    Last Post: 01-16-2014, 03:30 PM
  4. S Notes - keep getting "Unfortunately S Notes has stopped" Error
    By philmair in forum T-Mobile Galaxy Note 2
    Last Post: 01-14-2014, 09:17 PM
  5. Samsung Galaxy S3 stuck on software version 4.0.4
    By Bryn Lewis in forum Samsung Galaxy SIII I9300
    Last Post: 01-06-2014, 11:42 AM
