Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By IAmSixNine
    Harborseal's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Details on how the Note 3 knows to draw 2 Amps (instead of 0.9) when charging
    I've looked through as many charging threads as I could find. When you short the data pins (that's the 2 center pins, right?) The Note 3 knows it's a higher amp charging rate but how does it know if it's a 0.9 USB 3 port or a 2 A wall charger? Thanks. I'm trying to get a 4 A capable USB solar charger to provide the 2 A charging rate.
  2. #2
    IAmSixNine's Avatar
    Posts
    Global Posts
    3,291 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Details on how the Note 3 knows to draw 2 Amps (instead of 0.9) when charging
    The note its self doesnt know what your plugging it into.
    It only knows to draw a maximum amount of 2A of power.
    If you plug it into a device that only puts out 1A then the device will only get what the device can put out.
    It does have current limiting technology so if you use a 4A source the phone is designed to max out at 2A. As long as your source has regulated current output and protected from surges you can use a 4A source.
    Some cheaper made chargers have a tendency to have a voltage drop as the amount of current drain gets higher.
    SpookDroid likes this.
  3. #3
    FBA
    FBA is offline
    FBA's Avatar
    Banned
    Posts
    Global Posts
    2,465 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What he said!
  1. Which seems better to buy
    By vdyaulaw in forum General News & Discussion
    Last Post: 01-21-2014, 02:56 AM
  2. Should I disable data to conserve data usage and battery?
    By Tara100 in forum General Help and How To
    Last Post: 01-10-2014, 07:35 PM
  3. Microsoft Exchange Calendar to Google Calendar on N5
    By alibumaye in forum Google Nexus 5
    Last Post: 01-09-2014, 12:33 PM
  4. Replies: 5
    Last Post: 01-09-2014, 11:29 AM
  5. Anything I Should Know ??
    By abbbe in forum Google Nexus 7 (2012) Rooting, ROMs, & Hacks
    Last Post: 01-08-2014, 11:29 AM
