Results 1 to 24 of 24
Like Tree1Likes
  • 1 Post By hammill
    hammill's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default how to opereate the radio tuner in note 3
    first i have to say that I'm a bit new in the android world.
    i have managed to work with most of the features in my new note 3, some of them still left to learn.
    i have in my application manager an app. named 'ant radio service'.
    and the next line is 'ant+ plugins' .
    when i press to choose the ant radio service, it gives me options like - force stop, uninstall updates, turn off that looks like it already turn on.
    but how can i actually play it ?.
    is there no way to change/correct post name? (made some spelling mistake...).
  2. #2
    daves221's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: how to opereate the radio tuner in note 3
    hi hammill - unfortunately, you won't be able to play the ANT+ radio as it's not really intended for that. ANT+ is the wireless standard for interconnection with sensors, most commonly heart rate monitor, and cadence sensors used typically for cycling, jogging, etc. The standard is owned by a company owned by Garmin .. they started it for their fitness products and license its use. The intention for ANT+ in note 3 would be to collect that type of data when you exercise (rather than or in addition to using a garmin head end computer). The competitor to this is bluetooth for some fitness products now on the market who didn't want to license the ANT+ standard. Hope this helps. there are a ton of radio apps by the way that will let you stream audio over your regular data connection.
    hammill's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    o.k i see.
    i heard that there is some other app. you can install that do receive fm radio stations.
    can you recommend on one of them ?
  4. #4
    Deke218's Avatar
    Posts
    Global Posts
    336 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Take your pick.
    https://play.google.com/store/search?q=radio&c=apps
    I use TuneIn myself but all these streaming apps provide pretty much the same thing. Be aware that these apps stream radio using your data plan. The Note 3 does not have a built in FM radio.
    hammill's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    where from can i install it ?
    as i said , I'm new in this ares.
  6. #6
    Gator352's Avatar
    Posts
    Global Posts
    3,838 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you own the sprint version, the radio app is called nextradio. It streams but it also has a tuner to tune in to all local stations using your headphones as the antenna. Works like a champ and does not use data.
    hammill's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    how can i find if i have the sprint version ?
    i made a search in my device and it didn't find nextradio.
    edit.
    is says that nextradio isn't available for my device.
    I'll try to install tunein.
    edit 2
    installed tuneih. it works fine, don't have to use headphones as antenna. the reception is good .
    it says that my android is week and suggest me to install some cleaner.
    should i do it ?
    edit 3
    i realized now tat we're talking about internet radio, means that it only can play if the device is connected.
    is there any app. that gives you a regular tuner , receiving from air ?
  8. #8
    LimuHead's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No.
  9. #9
    LimuHead's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I mean don't press the ad to speed up your android. It's just an ad.
  10. Thread Author  Thread Author    #10
    hammill's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thank you.
    it looks that there is not an app. for regular 'on air' radio, only an internet one , is it correct ?
  11. #11
    rusty502's Avatar
    Posts
    Global Posts
    437 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    As stated, the Sprint version does have a built in FM radio tuner, uses the headphones as the antenna, not sure if the hardware is different or locked out in software on other versions.
  12. Thread Author  Thread Author    #12
    hammill's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    what is the 'sprint version' ?
    or what i have to do to have it?
    not sure if it's relevant but my note 3 is the n9005 model and i live in the meddle east.
    so if sprint is a cellular provider i suppose i can't use it.
  13. #13
    rusty502's Avatar
    Posts
    Global Posts
    437 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sprint is a USA wireless carrier, if nextradio is not on your device, and not available, then my guess would be that you do not have an FM tuner, sorry.
  14. #14
    eve6er69's Avatar
    Posts
    Global Posts
    6,449 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    you should have a sprint app icon for nextradio and by clicking it it should download. some phones dont even have the fm receiving capabilities. i know they were saying the not3 was going to have them before launch but they never came loaded with it. you may just need to use internet radio.
  15. #15
    rusty502's Avatar
    Posts
    Global Posts
    437 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sprint model number is N900P
  16. #16
    daves221's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by hammill View Post
    o.k i see.
    there's a lot of them and I'm not a big user so can't really recommend... there's iheart radio, rdo (I think), and many individual radio stations let you stream directly from their web site or have an app. There's also pandora, etc. some of which I think are free. Best bet is to search in google play and check some out... maybe others will jump in here too .. good luck...
  17. #17
    Jelly Belly's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I use iPlayer Radio to listen to BBC radio here in the UK. It is streamed live with only minimal delay from actual off air transmissions.
    I don't think you have grasped it yet.
    You don't need to use your headphone cable as an antenna. The Note 3 does not contain an FM receiver. Any radio stations you listen to on the phone through any of the apps are being streamed to your phone as data either via Wi-Fi or over your cellular network.
    Most Apps that play radio will not play anything local to you. If you are in Bahrain and want to listen to the local stations breakfast show you might be out of luck.
    Many stations have their own apps or allow you to stream through their web page so you might be lucky there.
  18. Thread Author  Thread Author    #18
    hammill's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i think that the note 3 ( as the s4) don't have a built in radio.
    when i try to download and install nextradio using play store it says " this item isn't available on your carrier".
    i guess it means that i can use only internet radio.
  19. #19
    rusty502's Avatar
    Posts
    Global Posts
    437 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    As far as I know, the only note 3 that has an FM tuner is the N900P, and it is only available on Sprint, all of the FM tuner apps in Google play State Sprint version only on note 3, so you will have to use one of the streaming radio apps. ..
  20. Thread Author  Thread Author    #20
    hammill's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Jelly Belly View Post
    bbc is great. i wish i could use it.
    yea, i suppose you right on everything you wrote.
    actually I'm in Israel and after installing TUNEIN RADIO it plays all the local stations i need , and more.
    sound quality is very good, also the variety.
    i just thought i can find a radio that doesn't use WiFi or cellular, but it looks it isn't available for me, so I'll just have to live with it
    thanks all for your help.
  21. Thread Author  Thread Author    #21
    hammill's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Bbc is great, I wish i could use it.
    Actually I’m in Israel and after installing TUNEIN RADIO I get all the local stations I need , and more.
    Sound quality is good , also the variety of stations and music styles.
    I just thought I could use a none internet radio but looks it isn’t available for me so I’ll have to live with it
    Thanks all for your help.
    Gator352 likes this.
  22. #22
    Gator352's Avatar
    Posts
    Global Posts
    3,838 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    edit.
    Next radio is only on Sprint devices, Sprint is a carrier like Verizon, AT&T, etc....
    edit 2
    should i do it ?
    Tunein is an internet app only. Does not "tune in" local radio stations therefore it doesn't need an antenna. And NO. Do not install a cleaner app.
    Edit 3
    NO. Unless your phone has an FM receiver, no app will work and act like like a radio. The Sprint version does. So I guess your stuck using internet streaming....sorry.
  23. #23
    Gator352's Avatar
    Posts
    Global Posts
    3,838 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Glad you found something that works for you
  24. Thread Author  Thread Author    #24
    hammill's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    GATOR352
    looks like you right in everything.
    btw, some members in android forum in my country are very angry on samsung that they didn't put the tuner fm chip in their latest devices ( they did put it in the S-3 and the note-2), unlike almost all of the other brands ( as far as i know they do have it in iPhone , Sony, lg, htc ) and some of them say they will conciser this issue before buying their next smartphone .
  1. Short Press on Home Button goes to recent apps
    By tlenzen in forum Samsung Galaxy S3
    Last Post: 09-29-2014, 10:01 AM
  2. Is it possible to use G2 camera app in GS4?
    By maskedcarrot in forum LG G2
    Last Post: 01-12-2014, 01:02 AM
  3. How to read exif data on S3 with android 4.3
    By Topshoeter in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-11-2014, 05:04 AM
  4. Replies: 3
    Last Post: 01-09-2014, 06:00 PM
  5. nexus 10, android in general
    By Neil Paice in forum Google Nexus 10 Tablet
    Last Post: 01-09-2014, 05:02 PM
