1. damdam109's Avatar
    my note 3 does not display the clock and date in lock screen, I compared it with my wife phone and she has the feature, I went into the lockscreen settings and went to clock widget everything seem right. Restarted the device multiple times and still no luck
    any ideas as to why?
    thanks in advance
    ChiribaoGA likes this.
    01-11-2014 08:55 PM
  2. kj11's Avatar
    Maybe you somehow deleted that widget? Try adding the "clock or personal message" widget to your lock screen...
    Sent from my SM-N900V using AC Forums mobile app
    01-12-2014 03:43 AM
  3. Johnny Chandra's Avatar
    thanks in advance
    04-05-2014 03:52 AM
  4. Johnny Chandra's Avatar
    Go to setting, date and time, select date format, choose the second one, do not choose the regional date
    04-05-2014 03:54 AM
  5. TNT1968#IM's Avatar
    Mine started doing it after the kit kat update. Lots of lags after it
    04-05-2014 04:11 AM
  6. Gator352's Avatar
    If you have lock screen widgets on, you might have swiped right or left where there is nothing. On your lock screen, at the top, swipe left and right.
    04-05-2014 06:10 AM
  7. heyitsejohn's Avatar
    This happens to me too. That's not it. In fact, I can't even add lockscreen widgets. (Yes, I have PIN and swipe turned off and yes I have multiple widgets switched on). It sucks because I was nearly late for an important meeting because of it.
    04-19-2014 08:23 PM
  8. anon8380037's Avatar
    Can you swipe to a lock screen page with a + box to add a choice of widgets. Screen lock should be swipe only. You seem to have heard of this, just checking if you are doing it right.
    Sent from my SM-N9005 using Tapatalk Pro
    04-20-2014 01:46 PM
  9. heyitsejohn's Avatar
    Yup. No screen security enabled, can't swipe to another screen. In fact, even with lock screen widgets turned on and set to either camera or favorite apps, I still can't swipe to them.
    04-22-2014 12:40 AM
  10. anon8380037's Avatar
    Don't know then. May be a phone or carrier issue. The lock icons should swipe up.
    Just to be sure this is my set up. (factory model)
    Also have a look at this thread for a GS3, this is how we worked it out, but it may not pertain to you.
    http://forums.androidcentral.com/sho....php?p=3551003
    04-22-2014 04:47 AM
  11. mx6_ls's Avatar
    Changing Date format worked well for me. Thanks for help
    11-25-2014 08:44 AM
  12. KillerQ's Avatar
    This worked flawlessly, thanks!
    01-08-2015 09:53 AM
  13. Azila Ahmad's Avatar
    thanks in advance
    Have you tried this?
    Settings --> Lock Screen --> Personal Message --> Edit Personal Message --> Thick Clock Box.
    07-07-2015 08:53 AM
  1. Replies: 10
    Last Post: 09-05-2016, 12:48 AM
  2. My Samsung S3 isn't in a reboot loop and I need files
    By James Seedorf in forum General Help and How To
    Last Post: 01-12-2014, 09:19 AM
  3. DashClock Expanded On Home Screen?
    By QueenCersei in forum General Help and How To
    Last Post: 01-12-2014, 04:40 AM
  4. Weird clocks on locked screen? Need help removing them
    By sarapoep in forum Verizon LG G2
    Last Post: 01-11-2014, 09:53 PM
  5. Problem with smart screen
    By AndroiderG2 in forum Verizon LG G2
    Last Post: 01-11-2014, 09:32 PM
