Results 1 to 7 of 7
    emiinn's Avatar
    Posts
    Global Posts
    259 Global Posts
    Default Sound with jack
    Do you guys notice a low sound when you plug in your phone with jack to a stereo or something?
    Is that even fixable. I've a beast stereo when it's plugged in to my pc and on my phone I have to set the volume of the stereo to max to have a bit of noisy music..
    All songs are good quality and amplified enough to play loudly
    NOTE 3 - Tapatalk
  2. #2
    Default Re: Sound with jack
    First thing - is it a low hum? does it change if you put your hand around the phone, or around the headphone jack on the phone while plugged in? have you tried a different cable? Also, instead of maxing the volume on the stereo, try turning that down and max out the volume on the phone first. Does that change anything?
    emiinn's Avatar
    Posts
    Global Posts
    259 Global Posts
    No its no low hum and I tried to reboot the phone. Can't try a different cable since it's build in.
    NOTE 3 - Tapatalk
  4. #4
    Hey dancing-bass, are you thinking what im thinking? possibly a grounding issue between his phone and the stereo?
    emiinn's Avatar
    Posts
    Global Posts
    259 Global Posts
    What means grounding?
    NOTE 3 - Tapatalk
  6. #6
  7. #7
    Are you plugged into a wall charger when listening? Try unplugging from the charger/power source and use battery only
  1. 2 way sync google contacts with Moto G is not working
    By User899 in forum Moto G (2013)
    Last Post: 04-09-2015, 04:34 PM
  2. Sony Z1S with ATT
    By STEVENK3102 in forum Sony Xperia Z1 Compact
    Last Post: 02-13-2014, 06:15 PM
  3. How Do I Pair My Nexus 7 Tablet with NFC-Enabled Speakers?
    By StLouisMan2 in forum Google Nexus 7 Tablet (2012)
    Last Post: 01-13-2014, 07:30 PM
  4. WPA2 Enterprise connection with Nexus 7
    By mfm77 in forum Android 4.4 KitKat
    Last Post: 01-12-2014, 07:58 AM
  5. trouble with WiFi fully connecting
    By jessatack22 in forum Droid RAZR M
    Last Post: 01-12-2014, 12:17 AM
