Results 1 to 19 of 19
Like Tree8Likes
  • 2 Post By msndrstood
  • 1 Post By vojopd
  • 1 Post By z06mike
  • 1 Post By vojopd
  • 1 Post By msndrstood
  • 1 Post By Chema Martin
  • 1 Post By Nazty111
    vojopd's Avatar
    Posts
    Global Posts
    8 Global Posts
    Default Need some help sorting out wakelocks on the Note 3.
    Ok,I really need help.I was searching for issues for 10 days,and didn't find anything that could help me.
    I have some wakelocks(audioout_2,connectivityservice,mmc2_detect,powermanagerservice_wakelocks) and i don't know how to get rid of them !
    If anyone can look these photos and help me :/.
    I am not using GPS,location disabled everywhere(googlesearch,location,in weather,I deleted FACEBOOK,and lowered the number of wakelocks,but still have them).
    I am generally using phone for surfing,whatsapp(sometimes viber),youtube,etc.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,676 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Galaxy Note 3 - wakelocks problem
    Does the device sit idle a lot?
    vojopd's Avatar
    Posts
    Global Posts
    8 Global Posts
    I am using it normally,it isn't idle a lot.Battery can handle about one day with 5 hours usage(to 20%).But I have 1 hour of awake time...
  4. #4
    Posts
    Global Posts
    32,676 Global Posts
    Carrier
    Hard to look at the pics again on mobile. I will look when I get home.
  5. #5
    Posts
    Global Posts
    32,676 Global Posts
    Carrier
    Have you rebooted the device? It may be possible that some process is stuck.
    vojopd's Avatar
    Posts
    Global Posts
    8 Global Posts
    I did it couple of times,and it didn't help.I figured out audioout2_wakelock gets high when listening to youtube,then from sounds from whatsapp,viber,etc
  7. #7
    Posts
    Global Posts
    32,676 Global Posts
    Carrier
    Not sure what else to suggest. Sorry.
  8. #8
    msndrstood's Avatar
    Posts
    Carrier
    Stock JB 4.1.2
    I know this sounds cliche, but when something gets 'stuck' if a reboot doesn't work, I do a battery pull as well. I've never not had it work for me.
    Sent via The Big, Bad, Beautiful Note 3
    Golfdriver97 and vojopd like this.
    vojopd's Avatar
    Posts
    Global Posts
    8 Global Posts
    Ok,I did a battery pull tonight,charged it while it was turned off,and will see results tomorrow !
    msndrstood likes this.
  10. #10
    If you are getting a day's worth of use with 5 hours screen on time and still have 20% left, what exactly are you stressing about???
    rvhs03 likes this.
  11. #11
    Agreed, perhaps those are not the absolute best stats, but they are more than reasonable!...
    Sent from my Samsung Galaxy Note 3 via Tapatalk
  12. Thread Author  Thread Author    #12
    vojopd's Avatar
    Posts
    Global Posts
    8 Global Posts
    That was once...actually I can't go over 5 hours on screen with full battery(and I should be able to get at least 5 hours,that would be reasonable. i am on 53% of battery,with 3:30 hours usage,almost a day on battery,and phone was about one hour and 11m awake.
  13. Thread Author  Thread Author    #13
    vojopd's Avatar
    Posts
    Global Posts
    8 Global Posts
    Quote Originally Posted by msndrstood View Post
    Can I marry you man?Battery was amazing last day,it lasted about 2 days,with 5:30 hours on screen.And about 1h and 20 mins awake.That is really cool.And usage of os and system was about 10,11%.Today it is about 6 % each.Hope it gets better,and better.THANKS MAN !
  14. #14
    msndrstood's Avatar
    Posts
    Carrier
    Stock JB 4.1.2
    Quote Originally Posted by vojopd View Post
    You're welcome. Glad it was an easy fix.
    vojopd likes this.
  15. #15
    The prongs on the bottem where u plug the phone in sf could be slipping under bend them up alittle I had this problem and I fixed it I'm so f****** happy
  16. #16
    The problem is the issue will come back again very soon
  17. #17
    msndrstood's Avatar
    Posts
    Carrier
    Stock JB 4.1.2
    Quote Originally Posted by Yathani View Post
    Maybe, maybe not. I don't have them any longer.
  18. #18
    I used to have this problem bad and it does come back every now and then... I have great battery life when it does not, though. The problem always gets fixed after a reboot. Here's what I got yesterday:
    Couldn't be happier!
  19. #19
    Default Re: Need some help sorting out wakelocks on the Note 3.
    I've noticed a massive difference in wake locks reducing when turning off location services completely. Standby time is great when it is switched off. But it wasn't needed prior to the latest firmware update.oh well, gotta put up with it.
  1. How do I disable auto-correct on the Note 3's keyboard?
    By James Heilig in forum Samsung Galaxy Note 3 in Canada (Bell/Rogers/Telus)
    Last Post: 08-20-2016, 11:08 AM
  2. New Note 3 Owner
    By clitrenta in forum AT&T Samsung Galaxy Note 3
    Last Post: 03-10-2014, 03:46 PM
  3. Galaxy Note II Still Worth It? (iPhone 5 or Note II)...
    By GiftedSoul in forum AT&T Galaxy Note 2
    Last Post: 02-25-2014, 04:01 AM
  4. pg59img.zip for radio 11.16.3504.20_2 please help!
    By npunk42 in forum T-Mobile myTouch 4G Slide
    Last Post: 02-05-2014, 03:11 PM
  5. How to debug network data on Nexus 5/7
    By PR1MO1 in forum General Help and How To
    Last Post: 01-23-2014, 07:37 PM
