1. Amir's Avatar
    Guys I have not put any sim in my note 3. When I use phone without turning on airplane mode battery goes like crazy. But when I turn it on it does not drain that much. What is the cause? Is it that I am not using any sim? Or some other issue??
    Sent from my SM-N9005 using Tapatalk
    01-16-2014 09:27 AM
  2. mrsmumbles's Avatar
    Could be location services or the phone searching for a radio connection. If you don't need location reporting on, turn off location services in settings.
    Sent from my Nexus 5 using Tapatalk 2
    Amir likes this.
    01-16-2014 10:56 AM
  3. UJ95x's Avatar
    What do the battery stats show as the number 1 drain?
    01-16-2014 11:03 AM
  4. Amir's Avatar
    Here are GSM stats.
    Check 72% to 65% huge drain then I turn on airplane mode then return to normal.
    01-16-2014 11:18 AM
  5. Amir's Avatar
    01-16-2014 11:18 AM
  6. mrsmumbles's Avatar
    Here are GSM stats.
    http://img.tapatalk.com/d/14/01/17/a2e4u7uj.jpg
    http://img.tapatalk.com/d/14/01/17/9uju5ava.jpg
    http://img.tapatalk.com/d/14/01/17/9upa4asa.jpg
    It's location services and Facebook. They're always the likeliest culprits.
    Amir and JellyBeanGurl like this.
    01-16-2014 11:20 AM
  7. Amir's Avatar
    Thanks but I use fb all time but did not saw that much drain. Drain started at 72%, upto 65% then I turned on airplane mode then it returns to normal
    01-16-2014 11:24 AM
  8. Amir's Avatar
    I used with airplane mode all time battery functions normally. But without it after 75% battery drains like crazy. 😟
    01-16-2014 11:28 AM
  9. UJ95x's Avatar
    It's likely Facebook. You need to go into the app settings and change the refresh interval to manual instead of push. And turn off location services for the app
    Amir likes this.
    01-16-2014 11:36 AM
  10. Amir's Avatar
    Thanks i will try that out.. but why turning on airplane mode consume less battery? I use fb same way but battery drain faster if airplane mode turned off. Is it because I am not using any sim or other reason?
    01-16-2014 11:41 AM
  11. UJ95x's Avatar
    Without airplane mode the phone is using the radio to try and get those notifications. Airplane mode = no radio...no radio = no drain
    Amir likes this.
    01-16-2014 11:55 AM
  12. Amir's Avatar
    OK thank you 😁
    01-16-2014 12:00 PM
  13. Simon_y7's Avatar
    Using N3 for the last 20 days, I've been extremely pleased with its battery, nowhere close to my previous phone, HTC Rezound. But, after seeing 96% this morning, I was thrown off seeing only 15% six hours later, and the phone was unusually warm. I've never seen a number less that 40. All I know was that avast antivirus was running a scan at the time.
    01-17-2014 01:53 PM
  14. z06mike's Avatar
    The phone was warm because a) the CPU/GPU was being used intensively, b) the screen was on for an extended period, c) phone searching for signal, d) an app stuck using background data or e) a combination of those things.
    UJ95x likes this.
    01-17-2014 02:16 PM
  15. Amir's Avatar
    If there is no sim and you are not on airplane mode. The phone still search for signal and drains more battery or it does not?
    01-18-2014 12:21 AM
  16. Kettle's Avatar
    This is the reason that I put my phone in airplane mode while on an airplane. I am not afraid that the airplane will crash. Rather my phone will be dead from continuously searching for a network. I have landed with many dead batteries for failing to do so.
    Sent from my SM-N900V using Tapatalk
    Amir likes this.
    01-18-2014 02:45 AM
  17. Simon_y7's Avatar
    All of it is true theoretically, but none applied to my case. The six hours that drained the battery 70% were no different in phone use than any other six hour period prior.
    01-18-2014 08:20 AM
  18. Amir's Avatar
    But on MJ6 there was no problem with phone radio. I did not have any sim that time i could get descent battery life without turning on airplane mode. But on MJ7 a lot of battery being sucked up by phone radio. Phone standby for me sucks on MJ7
    01-27-2014 11:52 PM
  19. Amir's Avatar
    Does phone standby Time sucks on MJ7 for everyone or just me???
    01-29-2014 09:09 AM
  20. Amir's Avatar
    《BUMP》
    02-01-2014 09:39 AM
  1. Thinking about installing a 4.4.2 rom on AT&T S3
    By sigreddasparks in forum AT&T Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 01-27-2014, 08:26 PM
  2. Replies: 15
    Last Post: 01-22-2014, 02:28 PM
  3. Battery life running ART
    By beeare in forum Motorola Droid MAXX
    Last Post: 01-20-2014, 12:04 PM
  4. Newbie questions about Motox on prepaid
    By TheFlyingDave in forum Moto X (2013)
    Last Post: 01-17-2014, 11:01 AM
  5. Google Play Services - Battery Saving Lie?
    By Mikey47 in forum LG G2
    Last Post: 01-16-2014, 05:16 PM
