1. PierreChacko's Avatar
    Hi,
    I have got my Samsung Note 3 battery charged fully, however, when i go to settings > General > Battery, it shows me 30 sec on battery which according to me seems to be weird. The battery however performs well, its just that the info seems to be incorrect. I've tried to restart, shutdown, remove the battery & put it back in, it's all the same.
    Any expert advice? Let me know.
    Thanks
    Pierre
    01-20-2014 12:26 AM
  2. Kelly Burby's Avatar
    Hi,
    hmm, sound a great problem i think you should visit the nearest samsung support because the problem looks to be in the technical end !!
    Thanks
    Pierre
    01-20-2014 12:49 AM
  3. UJ95x's Avatar
    Hi,
    Thanks
    Pierre
    Welcome to Android Central
    When you fully charge the battery, it will reset the amount of time on the battery. Same will happen if you reboot at any percentage over 90% (Not sure why they do this)
    01-20-2014 12:51 AM
  1. Battery Usage, Cell Standby & Network mode ?
    By mdawdy in forum Samsung Galaxy S4 Mini
    Last Post: 08-06-2014, 02:38 PM
  2. Replies: 1
    Last Post: 02-03-2014, 08:15 AM
  3. Note 3 battery drain
    By Tvm123456 in forum AT&T Samsung Galaxy Note 3
    Last Post: 01-20-2014, 01:33 AM
  4. HTC One: Battery life
    By charlee08 in forum HTC One Google Edition
    Last Post: 01-20-2014, 12:58 AM
  5. Galaxy Tab 2 10.1 Possible Battery Issue
    By jeffgravis in forum Samsung Galaxy Tab 2 10.1
    Last Post: 01-20-2014, 12:23 AM
