01-26-2014 06:49 AM
31 12
tools
  1. tiaratan's Avatar
    Hi, i just bought my note 3 last sunday. I think that my battery drains fast because I only use it for texting and looking at the time. I also use chrome a little but it is very minimal.
    I got 18 hours of battery from 100% to 0%. And about 6 hours of screen time. Considering how I use my phone it drains fast. I turned everything off like gestures, airview, motion gps, bluetooth etc. It was also on power saving mode the whole time. Please help me what should I do. The brightness is also the lowest option. I followed all the battery saving tips but I still get saMe battery life.
    01-22-2014 06:07 AM
  2. kj11's Avatar
    6 hours of screen time is pretty damn good. Think you might need to temper your expectations....
    Sent from my SM-N900V using AC Forums mobile app
    Ommadawn and zmann like this.
    01-22-2014 07:05 AM
  3. Phalgun Gujjar's Avatar
    Great battery life
    Sent from my HTC One
    01-22-2014 08:54 AM
  4. z06mike's Avatar
    What he said!
    01-22-2014 11:25 AM
  5. dt808's Avatar
    Lol..
    01-22-2014 04:32 PM
  6. Almeuit's Avatar
    Your battery stats are fine.. What are you worrying about?
    Sent from my T-Mobile Note 3 using AC Forums.
    01-22-2014 04:35 PM
  7. anon8380037's Avatar
    Keep it turned off and just look at it.
    The battery might drain eventually though.
    Sorry. I'm in a funny mood and just joining in.
    You have a valid query but like they said maybe your expectations are too high, or you drafted it wrong.
    I think 2nd batteries are surprisingly cheap for a newish high capacity model. (15.00 here for an Anker)
    zmann and kj11 like this.
    01-22-2014 04:43 PM
  8. zmann's Avatar
    That sounds like great battery life.. In any case it's also great having spear batteries. I have 5 batteries. Never charge my phone, ever. Just keep on swapping batteries in a 5 battery rotation.
    THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
    anon8380037 and kj11 like this.
    01-22-2014 05:18 PM
  9. clevin's Avatar
    6hr is my minimum. I get anywhere from 6.5 to 8.5 screen on (although I don't do 100-0% regularly, I only do 85 to 30 most of the time).
    I think the key is to turn off all data when not in use.
    01-22-2014 06:50 PM
  10. tiaratan's Avatar
    I turned everything off. My brightness is also on the lowest level. I use it only for texting and most of the time I only look at the clock. I think with minimal usage and no extensive use like games or mobile data the battery life drains fast. Or is it really only up to 6 hours of screen time even though I only use it for texting.
    01-22-2014 07:18 PM
  11. wrich2005's Avatar
    What is your guys'brightness settings like? Mine aren't like that at all
    01-22-2014 07:22 PM
  12. mchi5's Avatar
    Yeah that's typical battery use. I usually have to charge my phone 2-3 times a day but I use my phone alot for texting and work emails
    As for brightness I usually have it set on automatic. And only occasionally do I need to adjust it manually
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    01-22-2014 08:16 PM
  13. tech_fan's Avatar
    I had a Samsung Galaxy S3 that the battery life was horrible. Then I switched back to Crapple and bought the iPhone 5. The battery life on the Note 3 is way better than the Crapple. I find that when I am in an area where coverage is poor, it eats the battery.
    Today, I used my phone in a low coverage area for 8 hours. I then watched a 15 minute video at home at relatively high volume and the battery still has 44% left. I also are a couple of calls and sent and received maybe 10 texts. Some have said that when they factory reset the device that changed the battery life for them. Another thread suggested you download GSAM. I chose to pay for the GSAM Pro which was about $2 at the Play Store. With the GSAM, you can see where your battery consumption is the largest and with which applications. It also shows you the temperature of the unit as well and also signal strength throughout the day. That might be something to consider. Or, get the extended battery for the unit or walk around with a spare battery.
    01-22-2014 09:21 PM
  14. anon8380037's Avatar
    You have them charging separately at home or on the road?
    Via one of those charging packs or docking stations?
    Even if anyone could afford it, they wouldn't be fully charged out of the pack, would they, to throw away later.
    01-22-2014 09:31 PM
  15. swisstrader's Avatar
    I'm mad as hell! I only get 3x what my iPhone got!
    01-22-2014 11:19 PM
  16. clevin's Avatar
    thats weird. From my experience, all you need is wifi and mobile data off when not use, then turn off background sync, you can leave screen brightness anywhere from 0-30%, it should do more than 6.
    Can you share some screen shots?
    01-23-2014 05:19 AM
  17. dragonsamus's Avatar
    Most screen time I ever had was seven hours. Six is usually what I get. I think six hours is great.
    Sent from my SM-N900T using AC Forums mobile app
    01-23-2014 12:39 PM
  18. FBA's Avatar
    Screen-on time is the killer.
    I have the phone idle for 5-6 hours while I sleep at night, WiFi ON, Sync OFF, Mobile data OFF, GPS OFF, Bluetooth OFF. It drops maybe 1-2% at best over 6 hours; that's all, but screen-on time runs the battery down quick, much quicker than phone use.
    6 hours of screen-on time with 18 hours of battery is insane. Try that on an iPhone or a BlackBerry and see what you get.
    Standby time on this phone is reminiscent of the old days on the old style, non-smart phones when they could sit in standby for a week at a time.
    01-23-2014 05:03 PM
  19. Ommadawn's Avatar
    When I first got my Note3, I was thoroughly unimpressed with the battery life as well. It took a couple of weeks for the battery to "settle in" and not I get much better performance - so much so that the spare battery I bought after the first week of use has yet to touch the phone. Give it a week or two of regular charge cycles and see if it doesn't improve, I'd say.
    01-23-2014 08:15 PM
  20. anon24860's Avatar
    My average screen time is 6+ hours according to GSam.
    01-23-2014 10:45 PM
  21. superairwolf's Avatar
    True. I got my note 3 this week and also got an extra battery kit. I immediately used both batteries. Both came with an initial charge of 70+%. Use during the first cycle was unimpressive. But after a couple recharges, both batteries give stellar longevity, way better than my experience with my S4's.
    01-24-2014 01:09 AM
  22. thegame161's Avatar
    Is this serious? That's very good battery life.. On average I get 4-5 hours screen time and 1 day total battery life
    I always carry a spare battery with my battery kit so battery life doesn't matter too much. Even got a 3rd battery
    01-24-2014 06:40 AM
  23. dragonsamus's Avatar
    A little over 7 hours of screen on time.
    Attached Thumbnails Note 3 battery life.-1390590988913.jpg   Note 3 battery life.-1390590998360.jpg
    01-24-2014 01:17 PM
  24. MedlongOne's Avatar
    I bought mine last Friday. After a couple days I noticed that I was getting about 8-10 hours on a charge with decent use.I did all the battery saving tricks too. Two days ago I noticed that Google Search was taking up about half the battery. I restarted the phone and turned off Google Now. I got down to 40% after 18 hours. Amazing. I think Google Now was a big part of the problem.
    01-24-2014 02:20 PM
  25. ballisticn8's Avatar
    What you also have to keep in mind is that the phone shuts down some of its processing cores when the screen is off and its not doing anything. As soon as you turn the screen on its ramping everything right back up expecting you to be using it. My GSAM battery results tell me that I get 15 hours and 59 minutes of battery life. This is with 4g on the entire time, GPS on the entire time, bluetooth on in the car, waze running while I'm driving, podcasts playing, and screen on use is about 4.5 hours. No powersaving mode, no wifi, etc. On a day of light usage (weekends) I can get to 18 hours unplugged and still have 50-60% battery remaining.
    anon8380037 likes this.
    01-24-2014 02:29 PM
31 12
  1. Can I power the Chromecast using an external battery pack?
    By thatguy97 in forum Google Chromecast
    Last Post: 04-27-2015, 12:34 PM
  2. Nexus 7: Is this normal battery usage?
    By FlyHighGuy in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-22-2014, 06:29 PM
  3. Problems with my battery
    By dsl4life in forum Google Nexus 4
    Last Post: 01-22-2014, 04:53 PM
  4. Battery stats only show 'Android OS' with very high usage (98%)?
    By geekynerd00 in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-21-2014, 11:11 PM
  5. Galaxy Note 3 overloaded and died
    By mickeymom69#AC in forum Sprint Samsung Galaxy Note 3
    Last Post: 01-21-2014, 07:47 PM
