1. aniketsahrma9865's Avatar
    1. How to sync contacts between iphone and note 3 continuously...like iphone contacts syncs just when any change is made to all the icloud devices...anything like that?
    2. Anyway to permanently hide messages and other things except calls from logs?
    3. Anyway to remove contact showing up from frequently contacted in favourites tab...it shows even after it is removed from logs.
    4. Anyway to link ME (myself) contact in contacts to facebook to sync display picture?
    5. Anyway to stop whatsapp from saving media(images, audio and videos) on phone. I already stopped media auto downloading from setting...Now its not automatically downloading, but get saved after downloaded.
    6. Anyway to change that cartoonish display of any contact which is saved without any pic.
    7. Anyway to disable or remove my magazine without rooting?
    01-22-2014 09:58 AM
  2. TheMacs's Avatar
    Good questions, all pretty specific.
    1. Not sure this is possible automatically. Of course you can do it manually back and forth, but why would you want to sync Apple to Android contacts?
    The rest are likely do-able, but I'm thinking most will require rooting. I'd strongly suggest looking at Tasker, and hitting it's wiki, as well as the forum on xda. Several others are very well versed and may be able to help you get this done.
    Good luck
    aniketsahrma9865 likes this.
    01-22-2014 11:41 AM
  3. tech_fan's Avatar
    Crapple does not make it easy to integrate between Android and them. I had an Iphone and still have a Mac. I had to convert all my contacts to Gmail. There is a way you can move the contacts from your Crapple to gmail once and then maintain it on the gmail side.
    The bad part...now my contacts are not in sync with my Mac so, I have to go to gmail to get the contacts. Its a PIA. But now that I have my Note 3, I do not think I will go back to the Iphone
    01-22-2014 03:29 PM
  4. aniketsahrma9865's Avatar
    Good luck
    Because I use both.
    Sent from my SM-N900 using AC Forums mobile app
    01-22-2014 07:14 PM
  5. aniketsahrma9865's Avatar
    Manually is much better lol
    01-22-2014 07:17 PM
  6. Phalgun Gujjar's Avatar
    1. You can do this easily. Just setup Google contacts sync on apple. : https://support.google.com/mail/answer/3008051?hl=en
    Sent from my HTC One
    01-22-2014 07:18 PM
  7. Phalgun Gujjar's Avatar
    This way you can keep both updated.
    I haven't come accros alternative for other problems
    01-22-2014 07:19 PM
  1. Mic problem after USB board change
    By shpope0531 in forum Samsung Galaxy S II Skyrocket
    Last Post: 05-18-2014, 01:04 AM
  2. Having charging problems loose charger?
    By Jeffery Lutge in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-28-2014, 01:48 AM
  3. Problem since installing KitKat test build
    By peejay1977 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 01-23-2014, 07:48 AM
  4. Problems with my battery
    By dsl4life in forum Google Nexus 4
    Last Post: 01-22-2014, 04:53 PM
  5. s3 keeps rebooting when starting some apps
    By chicho1989 in forum AT&T Galaxy S III
    Last Post: 01-22-2014, 09:13 AM
