Page 1 of 3 123 LastLast
Results 1 to 25 of 75
Like Tree3Likes
    Default Note 3 dead, not charging and won't turn on
    I dont know what to do anymore. Called att and they will send it within 6 business days. They want me to pay $14.95 for 3 day shipping. And i chose the free one. For the meantime can somebody help me if i can still turn it on while waiting for 6 days?
  2. #2
    Default Re: Note 3 dead, not charging and wont turn on
    Should of complained more they would of sent it over night for free... I used to work for them and overnight everything for free.
    Sent from my SCH-I605 using Tapatalk
    Quote Originally Posted by maxjivi05 View Post
    I asked if they can waive the shipping he said NO
    - - - Updated - - -
  4. #4
    FBA
    FBA is offline
    FBA's Avatar
    Posts
    Global Posts
    2,065 Global Posts
    I'm going to ask the obvious here -
    Have you tried other chargers and charging cables?
    Tried cleaning the battery terminals on the battery and the device?
    Did it die when the battery ran down, or did you turn it off and find it wouldn't turn back on again?
    I just haven't seen failures where the phone itself is the problem in cases like this. It just feels like a peripheral problem to me, not phone...
    Do you think the battery's dead, or is it that the phone won't turn on? I have seen more failures here with the chargers and cables on the stock charger, than the phone.
    Converted lifetime BlackBerry user, now on Samsung Note 3...
    Bye bye Blackberry, forever.
    Thanked by:
  5. #5
    +1 The chargers are not reliable a lot of them go bad and won't charge. The phone shouldn't of just shut off. I'd almost consider buying a new charger or testing one at the store to see if that would fix the issue.
    Or if you know someone with a Note 3 borrow theirs or swap batteries and have them charge yours if your phone don't charge it's self till your new phone is in.
  6. #6
    Golfdriver97's Avatar
    Posts
    Global Posts
    13,801 Global Posts
    ROM
    Stock Moto X
    When you plug it in to charge do you get any light or icon?
    Have you tried charging it for a few hours straight without trying to turn it on?
    Devices: Current: Nexus 5, Moto X, Galaxy Tab 2 (7.0); Retired: Galaxy S2 (Epic 4G Touch); Traded: Galaxy S3
    When I let go of what I am, I become what I might be - Lao Tzu
    Community Guidelines and also here
    Thanked by:
  7. #7
    Quote Originally Posted by chloeshotmom View Post
    - - - Updated - - -
    Too late now but I would have asked to speak to the store manager to get overnight shipping
    And dumb question here but did it get wet or get dropped?
    And I agree with others. Sound like it may be the charger or battery not the actual phone.
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    Thanked by:
  8. #8
    Do you have any friends with a note 3? If so, have you tried to put their battery into your phone? Or if not, buy a battery locally.
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    It happens last month. They sent me a new battery. Now, it happened again.
    There is no light when i charge it. No red light. I pull the battery out and charge there is no light either.
    It was 10% then goes down to 1% in a few minutes then died.
    I charged it when it was still 10% but its not charging at all.
    I dont have friends with note 3, i used 2 batteries no luck.
  10. #10
    Default Re: Note 3 dead, not charging and won't turn on
    Have you tried another charger and cable?
    Thanked by:
  11. Thread Author  Thread Author    #11
    I dont have extra charger... I tried to charge it now and it doesnt stop vibrating but wont turn on and wont charge.
  12. #12
    FBA
    FBA is offline
    FBA's Avatar
    Posts
    Global Posts
    2,065 Global Posts
    Any USB charger or computer with a USB port will charge it.
    Thanked by:
  13. #13
    Can you find someone with a microusb charger? It doesn't need to be usb 3 like the note 3, the standard usb 2 would work fine. Just about every recent Android phone and even some windows phones palmos/webos, Blackberry would use micro usb 2.
    Thanked by:
  14. #14
    Other than that, there are external battery chargers that you can buy or wireless charging options, if you need your phone up and running now, since it sounds like the phone still would work with a charged battery based on what you said
    Thanked by:
  15. #15
    msndrstood's Avatar
    Posts
    ROM
    Stock JB 4.1.2
    I think it's probably a bad battery. Mine turned off twice the other day. Even though my extended battery said 30% charge, I noticed for the past week or so I was getting fewer and fewer hours on a charge. I got A Zerolemon and haven't had the problem since. Just a thought. I know you said they sent you a new battery but it could have been a return and bad as well.
    Sent via The Big, Bad, Beautiful Note 3
    What?!...I'm msndrstood.
    Sent via Note 2
    Thanked by:
  16. #16
    Could be something wrong with the phone itself is not charging properly. One way to test it is to buy a battery charger () charge the battery and if it holds its your phone is the issue. If it doesnt hold then they could be sending you bad batteries (mostly reconditioned). hope that helps
  17. #17
    Quote Originally Posted by msndrstood View Post
    Maybe but the fact that the op tried 2 batteries makes it unlikely that both batteries were bad
  18. Thread Author  Thread Author    #18
    So you think its the battery not the phone? As you noticed i posted some issues about my phone the system ui has stopped every start up, i have unfortunately apps has stopped every time i receive a notifications. So u think guys its all about the bat?
  19. Thread Author  Thread Author    #19
    the phone is charging using the usb to the computer. and now its ON. so you think its the charger?
  20. #20
    Good chance.
  21. Thread Author  Thread Author    #21
    Do u know where can I buy a wall charger. I saw one only at ebay. And what will I do now to the coming phone? U think its better to use it and send this one back?
    i love my note 3
  22. #22
    Posts
    Global Posts
    13,801 Global Posts
    ROM
    Stock Moto X
    i love my note 3
    Try here: ShopAndroid - #1 Store for Android Accessories
  23. #23
    FBA
    FBA is offline
    FBA's Avatar
    Posts
    Global Posts
    2,065 Global Posts
    No, that's probably another story, but I suspected your charger was the issue, as posted above. You can get any 2.1 AMP USB wall charger and it will charge quickly, like your Samsung charger. Samsung owes you a charger under warranty, but it never hurts to have another one as well...
    Griffin makes a good 2.1 amp charger (same power as Samsung original) and Best Buy has them in stock for 30$. Just don't buy the Best Buy in-house brand (RocketFish). The Griffin is a good buy.
    I'm not sure which other issues you have with your phone, but from what I am reading above, it isn't anything to do with battery. Batteries don't cause issues like what you describe. Those issues are more a problem with the OS, or perhaps some rogue apps. There are a few solutions for that too, but I would need more detail before I can help...
    Thanked by:
  24. Thread Author  Thread Author    #24
    Thanks so much. How can i contact samsung regarding the charger?
  25. #25
    They are basically charging you 15 dollars for the charger.
    Sent from my SM-N900P using Tapatalk
  1. Turn off My Magazine / Flipboard
    By Bren Bren1 in forum Samsung Galaxy Note 3
    Last Post: 02-16-2014, 10:02 AM
  2. Battery gets down to 39% and then shuts down
    By evolefty in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-26-2014, 10:29 AM
  3. Anyone interested in the Framily Plan on Sprint?
    By Mark Zagotti in forum Verizon
    Last Post: 01-25-2014, 09:39 PM
  4. HTC One X has been slow in general lately and I'm not sure why
    By MFThomas in forum General Help and How To
    Last Post: 01-23-2014, 09:09 PM
  5. Phone Contact not syncing to Outlook via Kies
    By empeyg in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-23-2014, 06:13 PM
B
