Results 1 to 24 of 24
Like Tree1Likes
  • 2 Post By Nick Talsma
  • 1 Post By nayan350
    EpicInYourFace's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default WiFi Issues in Note 3
    I just recently bought a Note 3 , and i am starting to experience WiFi issues
    I have 2 routers both which are having a problem with my note 3
    1st: Cisco E900
    Problem: The note 3 connects but internet does not work , it says DNS error but it is working on every other device
    2nd : Some random router
    Problem: Whenever i try to connect , it connects but it keeps on saying Obtaining Ip address after 5 minutes it gives an error saying that my internet connection is too slow to connect
  2. #2
    nayan350's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: WiFi Issues in Note 3
    I fixed my problem. I am using connectify in my laptop. But my note 3 shows unstable wifi connection. Then I updated my laptop wifi driver. Then in note 3 I off wifi power saving mode by dialing *#0011#. Then I unchecked all notifications in the wifi advanced menu. That's it.
  3. #3
    note3owner's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    When you go to the 0011 menu uncheck power saving mode
    Sent from my SM-N9005 using AC Forums mobile app
  4. #4
    kevinm1000's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am having very similar problems with my Note 3 after updating to Android 4.4.2
    I can not connect to a secure wifi with password, the signal is strong however the device keeps trying to connect and eventually "Authentication error Occurred" appears
    I can connect through web based wifi in pubs and restaurants but not through this secure connection.
    It appears that the password typed into my device is not recognised by the wifi (I am using the correct password)
    I have tried the *#0011# to no avail
  5. #5
    Nick Talsma's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thumbs up Re: WiFi Issues in Note 3
    +1 for Nayan's solution, the main issue at hand definitely seems to be tied to the "Power Saving Mode" on the WiFi. I've tried a ton of things suggested by service techs and community members alike and this is the first idea that's done anything to help so far. If you look around, a number of forums are flooded with Note 3 users having this same issue regardless of service provider or router manufacturer and most threads still don't contain a helpful answer, so hopefully this one will bubble up to the developers for Google/Samsung to help isolate the source of the problem. Thanks for posting!
    anon8380037 and nayan350 like this.
  6. #6
    Alain_A's Avatar
    Posts
    Global Posts
    4,942 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by nayan350 View Post
    how did you get that???? or find???
    Although I never had a problem with my wifi at home. It is good to know
  7. #7
    nayan350's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Alain_A View Post
    It is connectify software. It turns my laptop to wifi hotspot.
  8. #8
    nayan350's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kevinm1000 View Post
    Always use update wifi driver in PC and update your router software. When using wifi you should off mobile data network. Also off wifi power save mode by dailing *#0011# then press menu (left button) then see wifi option. That's it.
  9. #9
    lattemaker's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I was having a similar problem so I did what you did and dialed *#0011# and turned off power saving. It worked! I also noticed that for my wifi network it said connected to 802.11n. I have a 802.11ac network, doesn't the note support 802.11ac? Why isn't it connected to that?
    Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
  10. #10
    Alain_A's Avatar
    Posts
    Global Posts
    4,942 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I was asking how did you know to dial that number??
  11. #11
    nayan350's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I faced this wifi problem in my note 3. Then I did lots of search in Google. And found it. Now No problem.
    Alain_A likes this.
  12. #12
    nayan350's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by lattemaker View Post
    Note 3 supports Wi-Fi 802.11 a/b/g/n/ac, dual-band, DLNA, Wi-Fi Direct, Wi-Fi hotspot. May be something wrong.
  13. #13
    lattemaker's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So why isn't it connecting via 802.11ac? I'm kind of a nob to this stuff.
  14. #14
    nayan350's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    May be something wrong. I don't know. Use others. Thanks
  15. #15
    siwayiti's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Who can help me , what is the problem with this phone , WIFI couldn't open , I tried update , tried restart... help !!!
  16. #16
    unleaded91's Avatar
    Posts
    Global Posts
    36 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Turn off bluetooth and see if the wifi issues gets solved.. this worked for me. .
  17. #17
    Sabah Uddeen's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am having very similar problems with my Note 3 after updating my phone
  18. #18
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Attachment 125317 what is the problem with this phone WIFI couldn't open , I tried update , tried restart... help
  19. #19
    jlh73's Avatar
    Posts
    Global Posts
    588 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine did the same thing. Tried everything. Finally just got it exchanged. Works perfect now.
    Sent from my LG-D950 using AC Forums mobile app
  20. #20
    Selvak's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi i bought Note 3 Neo. Model - SM-N750 4 months before it was nicely working since from the beginning but today when i reached my room mobile internet not connected i checked and done as per your instruction but still its not connecting. If i am going to wifi and type my wifi password its connecting and next 5th second its automatically disconnecting. Need your assistance to resolve this issue. Awaiting your response. Thanks, Selva
  21. #21
    CECASSOC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Had a similar problem with wifi working fine in Safe MOde, but shutting off within 30 secs in regular mode. Tracked the problem back to a recent update from McAfee Mobile Security which added Web Security features. For whatever reason, it flagged by WPA secure Wifi as "Unsecure" and kept shutting it down. By opening Web security in the App and turning off Wifi Security my problem was solved. For the record, it did this at TWO (2) separate (but both COMCAST) wifi locations. I find it hard to believe they were both compromised or being sniffed.
  22. #22
    Charo Chanel Davis's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you soooooo much for your solution! My Wi-Fi worked fine up until 3 weeks ago. Wi-Fi just stopped working for No reason. I had to go to best buy and get a Samsung Rep to flash my phone with the 4.4.4 update. Samsung couldn't figure out the issue with my Wi-Fi either. Checked my wifi with Clear as well. I had tried everything except a hard reset and replacing my phone. I finally came upon your post and voila! Disabled wifi protection on mcafee and my wifi works! Thank you sooo much again!
  23. #23
    AyaMe Nisa's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanx. Seems to work fine now.
  24. #24
    farhad has's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have problem with wifi and I check at a lot but not I have no idea ? so plz I need help !
  1. HTC One stuck in BootLoop and won't enter recovery ! please help
    By Dhaval Shah3 in forum HTC One Rooting, ROMs & Hacks
    Last Post: 01-05-2015, 07:35 AM
  2. samsung might disabled 3rd party s views in android 4.4.2
    By Tyler Lietz in forum Samsung Galaxy Note 3
    Last Post: 03-17-2014, 05:22 AM
  3. Wifi works great, but sometimes connects to a neighbors wifi.
    By kmcdonald22 in forum Samsung Galaxy S3
    Last Post: 01-26-2014, 09:46 PM
  4. Wifi Popup Notification
    By sitaqui in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-26-2014, 04:08 PM
  5. turn on USB debugging in recovery mode
    By Farsheed Shastri in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-24-2014, 12:02 PM
