I tried the cases thread, but for some reason a search of the thread, though it will show hits for "charging", most of the hits don't actually have the word in it. Broken in some way?
Anyway, I have several things I am concerned in a case,
#1, It needs to be compatible with a wireless charging solution (Loosing an $800 phone to a bad charging socket is not good)
#2, I don't have the biggest hands, so I have to be careful about adding too much to the middle of the phone.
#3, The corners need some fall protection.
About #1, Most of the messages about covers don't mention wireless charging, like the Qi compatible charging solutions. The official Qi back from Samsung, seems to add enough thickness that it would seem to rule out most cases. But, there seem to be 3rd party Qi receivers that fit under the existing cover. However, I wonder if the extra thickness of a case will be an issue with wireless charging.
In regards to #2 & 3, I know that most impacts with the floor will first be on a corner. So, that is where the padding needs to be. The S-View covers seem to omit covering the corners entirely. So they would be useless in a fall. Even a little leather covering the corner would reduce the severity of the impact. Ideally, the corner would have a silicon-type of rubber covering, and the thickness would be OK there. The extra thickness would be of little benefit to the middle edges of the phone, and perhaps make holding it a problem for me.
Is there a case that meets all of my needs?
Thanks,
Joe
Thanks,
Joe
