Results 1 to 8 of 8
    Default issues with samsung micro sdxc uhs-1 pro card
    Hi recently brought a samsung
    Micro sdxc 64gb uhs-1 pro card.
    Installed it into my note 3 formatted the card reads about 62 gb of free memory.
    Downloaded some films onto the card l converted that I used to play on my old galaxy s2 but they wouldnt play.
    Intalled the same film on the phone memory instead of the card and played fine.
    Also when I plug the memory card into the pc and format it it only reads 30 gb of memory any body got
    any ideas?
  2. #2
    Default Re: issues with samsung micro sdxc uhs-1 pro card
    I can almost attest that the card is bad.. I had one of those cheap fake 64gb class 10 cards, and had problems with it, even before I got my Note 3. They have a lot of fakes out there. Since then, I have got two Sandisk 64gb class 10 micro sd cards and put them in my Note 3 and Note 2014. Formatted each one in the device they are in. Proceeded to put all my movies, pictures and music.. They work flawlessly. Get another sd card, format it in the device and yoiu should be good to go.
    EDIT. I just noticed that you stated you DOWNLOADED some movies.. If that is the case, that might be the problem. I don't mess with that downloaded stuff, they have too much crap in them, and may or maynot work when you copy them. I take my purchased DVDS and CDS and convert and copy them to my Notes, that works. IMO, with downloaded media, there are too mnay tricks and turns for me.
  3. #3
    First make sure it is formatted in exFat file system. NTFS and FAT32 are not good for removable flash storage over 32GB.
    I would check to make sure it is legit. Something isn't adding up. My 64GB SanDisk card shows 59.xxGB when formatted. It has worked great since day 1
    Posted via Android Central App on my Note 3
    I ment I downloaded them from my pc
    They were converted from my dvd collection
    They all worked fine on my s2.
    Got the card from ebay
    Samsung brand looks legit
    Packaging etc. The way I see if a memory card states 64g then it should be 64g weather its in a phone or in my pc I would of thought..
    When I first installed it into my phone and fomatted it tried to put music on etc. Put it back in the pc and files etc on it were in symbols nothing made sense
  5. #5
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by galaxynote3user42 View Post
    Then the SD card is corrupted. Put it into your PC and run chkdsk to try and fix it.
    The first step in this post will show you how in case you don't already know
    "Damaged SD Card"....(this is how I recoverd my data)
  6. #6
    The shown capacity size difference is because of how the capacity is calculated.
    Most drive manufactures use a base 10 system. So 64GB would mean 64,000,000,000 bytes. When most Operating systems calculate the size using the binary method of 2^10. With binary 1KB=1024 Bytes and 1MB=1024 Bytes. As you move larger and larger the difference from the two standards grows.
    With the above math a also GB card would show a size of =59.6046447754GB
    Found this article to explain it http://knowledge.seagate.com/article...S/FAQ/194563en
    This is the way it had been for decades unfortunately
    But if your is showing a different capacity then something is wrong.
  7. #7
    I should point out that my math is based on exactly 64 billion bytes. That number is likely not exactly hit Spot on. So there could be slight variation based on tech to reach that number. But should be relatively close.
  8. #8
    Quote Originally Posted by UJ95x View Post
    "Damaged SD Card"....(this is how I recoverd my data) - Android Forums at AndroidCentral.com
    Yup, that worked on my wife 16gb micro sd card too.
    She was filled up, couldn't copy anything off card, a last ditch effort, I did a cmd, at the dos prompt "chkdsk H:"... After that, was able to copy all files off the card and formatted it correctly.
    Also, there are a lot of FAKE 64gb cards out there too. Here is one for sure, they are on Ebay and Amazon..
    Amazon.com: 64GB class 10 Micro SD Memory Card with free SD Adapter: Computers & Accessories
  1. My Headphones aren't working with my Moto X
    By Maxine Rawlinson in forum Moto X (2013)
    Last Post: 11-21-2016, 02:30 PM
  2. Need some help with rooting.
    By editionfws in forum AT&T Samsung Galaxy Note 3
    Last Post: 02-01-2014, 09:27 AM
  3. Samsung security update notification
    By mty msi in forum AT&T Galaxy S3
    Last Post: 01-27-2014, 07:59 PM
  4. Replies: 2
    Last Post: 01-25-2014, 07:41 AM
  5. Music Player & Kies issue
    By Hystericallify in forum Samsung Galaxy S3
    Last Post: 01-25-2014, 05:07 AM
