1. Yathani's Avatar
    Hello people,
    So i decided to install the Poland 4.4.2 on my N9005 note3. I had some problems but I was able to fix but now i'm stuck with this one. In my contacts the alphabet on the right side, it appear to have an issue that I don't know how to fix " Look at the picture". I tried to clear the data/catch but it doesn't seems it can fix it. Any idea would be appreciate it
    Cheers!
    01-26-2014 02:56 PM
  2. Yathani's Avatar
    Deleted all of my contacts and still shows the same thing. Same problem on my S4 with 4.4.2.
    01-26-2014 02:58 PM
  3. vsnlweb's Avatar
    That's because it's not a problem... Usually they do that to truncate letters that are not in use or don't have much names in there...
    Sent from my SM-N900W8 using Tapatalk
    01-26-2014 03:01 PM
  4. Yathani's Avatar
    I don't think so.
    I have 11 names that start with M and 1 with L,so it should show it. Also I deleted all the contacts and it behaved the same way.
    Thanks for your inputs
    01-26-2014 03:11 PM
  5. steve short's Avatar
    Are the Contacts still viewable? If not could they be in sim or phone contacts and not showing up?
    Sent from my SM-N9005 using Tapatalk
    01-26-2014 03:28 PM
  6. Yathani's Avatar
    Yes they are. It even enlarge the letter M and L when i point my finger on the dot between K and N.
    Thanks Steve
    01-26-2014 03:33 PM
  7. Yathani's Avatar
    Anyone with KItkat have this problem? if not then which build are you running?
    Thanks
    01-27-2014 11:14 AM
  8. howdidoo's Avatar
    LOL.. I noticed this issue after reading this post. I have the L & M missing too. I am running Android 4.4.2 on Singtel (Singapore)
    01-27-2014 08:42 PM
  9. Yathani's Avatar
    Glad to know I'm not the only one.
    01-27-2014 11:39 PM
  10. sukesh123's Avatar
    Hi,
    Even i have the same problem. I have more than 20 contacts in L and around 30 in M. still it is not showing L and M in the list.
    Nice observation though :-).
    I'm running android 4.4.2 on Maxis Malaysia.
    01-28-2014 12:38 AM
  11. Kettle's Avatar
    Easy fix. I will just delete all my L & M contacts. :-)
    Sent from my SM-N900V using Tapatalk
    01-28-2014 01:20 AM
  12. howdidoo's Avatar
    Genius. Applause.
    01-28-2014 01:27 AM
  13. zocster's Avatar
    Same issue running polish Kitkat haven't tried others yet. There are a few out now, Netherlands seems to be best
    Sent from what ever device I got my hands on via Tapatalk
    01-28-2014 01:58 AM
  14. vsnlweb's Avatar
    Well that's an odd thing to add to kit Kat. Maybe it's because it is the middle of the alphabet or something... I dunno... Have you tried changing any of the settings for contacts and see if it changes.
    01-28-2014 06:58 AM
  15. Gator352's Avatar
    Maybe Koreans don't use a L And M in their alphabet and forgot that others do
    01-28-2014 11:32 AM
  16. Yathani's Avatar
    My Galaxy S4 with 4.4.2 has the same issue as well.
    01-28-2014 01:18 PM
  17. szentmihaly's Avatar
    Same here. I noticed this when my software updated to 4.4.2. Now it's driving me crazy. Did anyone come up with solution? (same letters missing)
    02-01-2014 09:03 PM
  18. FBA's Avatar
    Kit Kat makes a better chocolate bar than OS!
    Amir likes this.
    02-01-2014 11:07 PM
  19. howdidoo's Avatar
    Ok.. I got another update last night from Samsung/Singtel. It was a small 40mb update and the only thing mentioned in change log was "Stability improvement". I will monitor this now and see if life is back to normal.
    Update 1. Yoohoo, my Contacts showing the missing L & M. The bug has been quietly removed.
    02-25-2014 08:46 PM
  1. Note 3 rear camera not focusing
    By Twisted Shadow in forum Samsung Galaxy Note 3
    Last Post: 07-16-2016, 07:45 AM
  2. I'm having issues when receiving pictures on my LG G2....
    By Robman87 in forum General Help and How To
    Last Post: 01-28-2014, 12:53 AM
  3. Replies: 4
    Last Post: 01-28-2014, 12:46 AM
  4. Galaxy Note 10.1: Gallery problems
    By irshadkylm in forum Samsung Galaxy Note 10.1
    Last Post: 01-26-2014, 01:48 PM
  5. I'm having issues when receiving pictures on my LG G2...
    By Robman87 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-26-2014, 12:43 PM
