1. Bernard Borg's Avatar
    Hi all, I am asking if anyone encountered this or knows how to fix it. Yesterday late afternoon Android Kit Kat for my note 3 was available silly me i opted for the upgrade suddenly the phone is very sluggish, un responsive after unlock ( basically I found that if you slide down the notification toolpane it works, you press on setting so the ui starts to get commands.) home button and back slugish take an awful amount of presses to respond ( was my upgrade broken ?)
    Help is appreciated
    Bernard
    01-29-2014 08:22 AM
  2. zmann's Avatar
    Try a reboot. Most likely you did that so seeing as how you just installed the new update if this was me I would just do a factory reset.
    THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
    01-29-2014 11:03 AM
  3. srkmagnus's Avatar
    Try a reboot as suggested above. If that doesn't fix your issue completely consider a factory reset, which should help clear out that problem.
    01-29-2014 12:03 PM
  1. Sprint Note 3: KitKat where is it and when will we get it
    By rollinwit9 in forum Sprint Samsung Galaxy Note 3
    Last Post: 02-28-2014, 09:54 PM
  2. Samsung Note 3 no service ..common fault Sim card reader faulty?
    By rexnong in forum Samsung Galaxy Note 3
    Last Post: 02-03-2014, 10:55 AM
  3. Build quality on Samsung Galaxy Note 10.1 2014 :( SOS
    By Astronomer cykiller in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-30-2014, 05:21 PM
  4. Question on build quality and durability
    By skirush2014 in forum Samsung Galaxy Note 3
    Last Post: 01-29-2014, 10:03 PM
  5. Replies: 6
    Last Post: 01-29-2014, 02:42 PM
