1. rajnet's Avatar
    I am down to 5% in 6 hours with moderate usage. Any way to check rogue apps? Device is also getting heated up.
    01-30-2014 09:36 AM
  2. xceeder's Avatar
    Go into settings and check your battery status that will give you a good idea which apps are using the most power and some tips - turn off auto sync , turn down the brightness on your screen and log out of apps like Facebook/twitter ...
    sent from my Nexus 7 using tapatalk pro..
    01-30-2014 09:41 AM
  3. mchi5's Avatar
    I heard the Facebook app is notorious for draining our batteries. However I leave my on anyways )
    Sent from my Galaxy Note 3 via Tapatalk
    JellyBeanGurl likes this.
    01-30-2014 10:05 AM
  4. xceeder's Avatar
    That's probably why your battery is draining so fast lol
    01-30-2014 10:24 AM
  5. TheMacs's Avatar
    Reboot. Power down the device, pull the battery, replace, power on.
    9 times out of 10 (more than this really) this works. Unless your a power user (rooted, non-stock ROMs, overclocking, etc.) who's pushed your Note.
    msndrstood and rajnet like this.
    01-30-2014 11:59 AM
  6. JellyBeanGurl's Avatar
    Yup Facebook will drain it for sure!
    If I don't use the Facebook app, I get almost 7 hours of battery time. If I use the Facebook app, I'll get 5-6 hours. Stinks!!
    Sent From My Samsung Note 3 using Tapatalk
    rajnet likes this.
    01-30-2014 12:23 PM
  7. rajnet's Avatar
    Thanks everyone will try all options.
    01-30-2014 04:04 PM
  8. z06mike's Avatar
    Download gsam battery monitor and see what is killing the battery. That is waaayyyy too fast for the battery to be dying, unless the screen was on 100% of the time.
    Sent from my SM-N900V using Tapatalk
    01-30-2014 05:24 PM
  1. Note 3: S View cover drained battery??
    By shastrich2005 in forum Verizon Samsung Galaxy Note 3
    Last Post: 07-24-2014, 09:40 AM
  2. Replies: 7
    Last Post: 01-30-2014, 07:07 PM
  3. Samsung Galaxy S2 - Chargers draining battery fast
    By Toadybum in forum Bell Galaxy S II
    Last Post: 01-30-2014, 12:09 PM
  4. Facebook notifications causing significant battery drain.
    By Ray999 in forum Android 4.4 KitKat
    Last Post: 01-30-2014, 12:56 AM
  5. Battery Problem
    By DaviPeixoto in forum Moto X (2013)
    Last Post: 01-29-2014, 04:54 PM
