1. Iso10's Avatar
    I don't know if I should post this here or in the general android forums but what really matters and is really annoying is this bug I am facing on Facebook .. The profile pictures of people, pages and even mine is not showing up but it was there in the past I don't know what is the matter .. I tried everything from re logging to clearing cache and data and even uninstalling but with no luck .. am I the only one who is facing this problem ?? I want any help because this is really frustrating and thanks in advance
    02-01-2014 12:35 AM
  2. rvhs03's Avatar
    No problems as you described here
    02-01-2014 12:43 AM
  3. JellyBeanGurl's Avatar
    Hmm. Have you tried this? Uninstall app, restart phone, clear cache at reboot, and then reinstall, in this particular order? I can't think of anything else.
    Sent From My Samsung Note 3 using Tapatalk
    02-01-2014 01:05 AM
  4. jcampbell1070's Avatar
    Ive had some problems with not seeing pics. And stuff people put up. I guess facebook has problems sometimes
    02-01-2014 01:07 AM
  5. Iso10's Avatar
    I have just tried that and it didn't work .. The pps aren't showing on the Facebook app , messenger app , or on the Facebook site on the browser that's why I am saying that is a problem .. because they were showing up in the beginning
    02-01-2014 07:42 AM
  6. Iso10's Avatar
    Jcampbell and what did you do to solve this issue , as you are saying you were having problems ..
    02-01-2014 07:43 AM
  7. Iso10's Avatar
    My god I have even tried to switch to the https:// desktop site on the browser and still the pictures just refuse to show up X(
    02-01-2014 07:54 AM
  8. rivencap's Avatar
    It's honestly Facebook. I'm a beta tester for the android app. Huge problems. Hope this helps with reassurance at least.
    Palm Treo line > BlackBerry line > Samsung Galaxy S line > NOW the awesome & powerful Samsung Galaxy Note 3! 😆📱😆
    02-05-2014 04:11 PM
  9. pdub73's Avatar
    This sounds more like a problem with a setting or an app...it seems to be specific to your device, unless anyone else is having this problem...I would first try setting all ur settings back to default...for example any settings you may have changed in your developer options...and if you can remember when it last worked properly, remove any apps you recently installed...test each one to see if that may be the cause...
    Sent from my SM-N900V using AC Forums mobile app
    02-05-2014 11:07 PM
  10. kevinpleasants's Avatar
    Its actually the way Facebook is now showing the pictures and status. Its a mess, but it appears Facebook is only showing a certain amount of our ffoends our status. Smh
    02-05-2014 11:21 PM
  1. Nexus 7 (2013) headphone jack problem
    By Enricke Kee in forum Google Nexus 7 Tablet (2013)
    Last Post: 11-03-2016, 07:32 PM
  2. Galaxy S3: Problems with default e-mail application
    By cb2367 in forum Sprint Galaxy S III
    Last Post: 04-18-2014, 11:31 AM
  3. Facebook battery DRAIN
    By Ryan Rickerson in forum AT&T LG G2
    Last Post: 02-12-2014, 02:37 PM
  4. Xperia Z1s: No problem with the viewing angle...
    By surfaday in forum Sony Xperia Z1s
    Last Post: 02-10-2014, 08:31 PM
  5. A thread problem in Android Central App!
    By Arkhos in forum Site Feedback & Help
    Last Post: 01-31-2014, 11:31 PM
