1. Akshay T's Avatar
    We just bought a new Note 3 (4G version). The problem is that the wifi is not turning on. The screen just says "Turning On...", but nothing is actually happening. Can someone please advise on this? Thanks a lot!
    02-01-2014 08:03 AM
  2. srkmagnus's Avatar
    Reboot the device and try again - It shouldn't get stuck at turning on. If that doesn't help try a factory reset and see if that fixes the problem.
    02-01-2014 10:05 AM
  3. Raam Kmr's Avatar
    there s no using of factory reset pls helpus
    04-22-2014 11:02 AM
  4. bclinger#IM's Avatar
    Are you using a dual band router?
    Sent from my SM-P600 using Tapatalk
    04-22-2014 01:24 PM
  1. Deleting Phone Contacts but NOT Google Account Contacts
    By nixgnzlz in forum General Help and How To
    Last Post: 02-01-2014, 10:27 AM
  2. Note 3 text notifications not working
    By Gaby Smith in forum Samsung Galaxy Note 3
    Last Post: 02-01-2014, 10:08 AM
