1. anon8488674's Avatar
    I like the bubbles live wallpaper.
    Does it eat much battery or is it negligible?
    Via my Galaxy Note 3
    02-05-2014 06:32 PM
  2. B. Diddy's Avatar
    Most simple live wallpapers will use minimal battery. The ones that tend to use more are the very graphics/animation-intensive ones, or the ones that access the web often (like weather wallpapers). Some live wallpapers also seem to be coded poorly, because I've encountered some that periodically start sucking battery for no clear reason, then calm down after a reboot.
    Golfdriver97 likes this.
    02-05-2014 06:57 PM
  3. Golfdriver97's Avatar
    Most of the stock ones, which I believe is what you are referring to, shouldn't be that big of a deal. It is the 3rd party ones like B. Diddy alluded to that can eat battery power. Beat thing to do is try them, and just keep an eye on your meter.
    From a Sprint Moto X using AC Forums app
    mumfoau likes this.
    02-05-2014 07:14 PM
  4. Beantown Bashers's Avatar
    I have been using the koi live wallpaper and it does not drain battery.
    The stock wallpaper should not have any issues. If you download and use a live wallpaper keep an eye on it for the first few days to see how it uses resources.
    02-05-2014 07:47 PM
  5. anote3fan's Avatar
    I used the Deluxe Live Ultra HD Planet... and it drained the battery like crazy... it was awesome though..
    02-07-2014 11:52 AM
  1. Galaxy S3 - Fix for 4.3 freezing, lagging and battery life
    By fesouza in forum Samsung Galaxy SIII I9300
    Last Post: 08-26-2014, 01:13 AM
  2. Note II Battery...
    By GiftedSoul in forum Samsung Galaxy Note 2
    Last Post: 02-28-2014, 05:53 AM
  3. Zero lemon 10000 battery
    By viper31573 in forum Verizon Samsung Galaxy Note 3
    Last Post: 02-17-2014, 01:19 PM
  4. Ocean Ruins 3D - Live Wallpaper
    By sofiene71 in forum Wallpapers, Ringtones, and Themes
    Last Post: 02-06-2014, 10:12 AM
  5. why does my phone charges slow and drains battery so fast?
    By Unisauruss Rose in forum Google / Samsung Galaxy Nexus
    Last Post: 02-04-2014, 05:06 PM
