Results 1 to 24 of 24
Like Tree8Likes
  • 1 Post By Gator352
  • 1 Post By dpham00
  • 2 Post By dpham00
  • 1 Post By anon8380037
  • 2 Post By dpham00
  • 1 Post By beh
    Default Those who use the samsung wireless charging pad- how long does it take to charge?
    Tempted to buy the S view wireless cover...those that have the s view cover and the samsung charging pad roughly how long does it take to fully charge to 100%?
  2. #2
    Default Re: Those who use the samsung wireless charging pad- how long does it take to charge?
    I'm also interested in the time difference. I get a full day out of my phone anyway and charge overnight.
    Is wireless much slower?
    Sent from my SM-N9005 using AC Forums mobile app
  3. #3
    I don't use the actual Samsung charger but I do use the Choe (updated version) I got from amazon. There is about an hour difference. Some might say it takes longer and some might say it takes less but in my experience, it's about an hour.
    I charge my phone overnight also so the extra hour is a no-brainer for convenience of just plopping the thing down.
    PrinceEpyon likes this.
  4. #4
    Closingracer's Avatar
    Banned
    Posts
    Global Posts
    4,803 Global Posts
    So far i am using my nexus wireless charger that came out with the nexus 5 or soon after ( not the circle one that came out) and does it overnight. I bought the tylt Vu charger and hopefully just as fast. I just found it so annoying i always have to find the right spot on the nexus wireless charger
  5. #5
    Probably somewhere around 4-5 hours for 0-full
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
  6. #6
    Huh? No. About 3 hours from 0 to full. Mine charges just as quick plugged in from 0 to 90 as it does wirelessly. It just takes longer from 90 to 100.
    Posted via the porcelain throne.
  7. #7
    I was also thinking about picking up a wireless charger. Thanks for the info.
  8. #8
    Quote Originally Posted by Gator352 View Post
    Interesting, I just assumed that the Samsung pad took as long to charge as the LG or nokia pads that I have.
  9. #9
    Default
    I'm using the Samsung charging back and the Choe charging pad. I can't comment on the Samsung charging pad. I should have explained that a little better.
  10. #10
    I am using the Samsung back as well. The choetech back ran hotter and didn't charge as fast as as my lg and Nokia pads.
  11. #11
    Default
    Could someone fill me in please? I never looked into this.
    Is the wireless back pre-charged so it's an extra power pack. Or is it like I think - another way to charge the battery without a direct connection to an outlet?
    The battery charges SUPER fast on AC ( < 90 mins), and even with a 1.0A car charger it's fast.
    What is the range away from the base unit thingy.
    In other words - what is the point of carrying a larger heavier pack around?
    I can put the small 1A ac charger from my GS2 in my coat pocket.
    Is it not just a novelty item?
    Via my Note 3 on AC.
  12. #12
    Quote Originally Posted by dpham00 View Post
    You might have had a defective unit. Mine doesn't get hot and it charges pretty fast. Although I have nothing to compare it too except my wife's and hers is the same setup as mine.
  13. #13
    I tried it with the choetech back and about same charging rate. I do have a very thick case (Trident Kraken ams), so that could have an impact
  14. #14
    Quote Originally Posted by Madd54 View Post
    It is another way to charge without having to plug a wire into the phone. This is for those who don't want to run a wire from the charger to the phone, really no other advantage
    anon8380037 likes this.
  15. #15
    Not even close to being novelty and it's not a battery pack.
    You can either get a Samsung wireless charging back (black or white on Amazon) or use a charging coil that fits under existing battery cover. The Samsung back IS thicker and the coils make the back bulge a little... So it's a trade off. Then you can buy ANY qi charging pad you wish.
    Once you do this, all you have to do is set it down and walk away...or go to sleep....your choice Check em out below!
    Amazon.com: samsung note 3 wireless charging cover
    Amazon.com: samsung note 3 wireless charging coils
    Amazon.com: qi charging pad
  16. #16
    Ok that makes sense. See, if I use my charging coil and place my phone in it's Seidio Dilex case, it gets HOT. 112 degrees + and takes longer to charge. But if I use the Samsung cover with no case, its perfect.
  17. #17
    OK So you never forget to charge it. That's an advantage. Thanks.
    Sent from my SM-N9005 using Tapatalk Pro
  18. #18
    At work when I don't use it I can put it on the pad. Especially on days when I walk away from my desk a lot. At night, I use this charger because sometimes I will knock my phone on the ground in the middle of the night or grab the phone forgetting that the cord is in
    anon8380037 and Gator352 like this.
  19. #19
    It's acts like a 1.0A charger from what I can see. I learned from @clevin and @rusty502 that it's good for the battery to top up from around 50%, as it stays cooler and counts as half a cycle, so mid top ups are fine. 30%-80% range regularly is healthy.
    I mostly drive at the mo so would consider one when I'm in a second room or an office a lot.
    Good to know.
    When you put your night ravaged phone up for sale it won't be me putting a bid in. LOL.
    Gator352 likes this.
  20. #20
    Welcome!
  21. #21
    Good to know.
    It is in a Trident Kraken ams case and covered by a meme tempered glass screen protector. Looks brand new, once you remove the screen protector and case.
    No worries though I never sell my phones.
  22. #22
    I never sell my phones either. I either give them to family members or just keep them as backups.
  23. #23
    Yeah I give my phones to family members on prepaid, since most Verizon 4GLTE smartphones are factory sim unlocked anyway.
  24. #24
    beh
    beh is offline
    beh's Avatar
    Posts
    Global Posts
    1,413 Global Posts
    Using the Samsung wireless charging back and the TYLT charging base it takes noticeably longer than using a cable and a 2.1 amp output charger. In addition, with the Samsung wireless charging back installed (not the charging cover back) I lose the NFC and SBeam functions. Seems like the thicker charging back blocks the NFC radio signal.
  1. transferring data to new google phone
    By chenks in forum Google Nexus 4
    Last Post: 02-07-2014, 02:59 PM
  2. How many returning the red Nexus 5?
    By reneeh63 in forum Google Nexus 5
    Last Post: 02-07-2014, 12:18 PM
  3. Replies: 5
    Last Post: 02-07-2014, 04:24 AM
  4. Aio Wireless drops prices, increases data allotments
    By prepaidguy9081 in forum Other US Carriers
    Last Post: 02-07-2014, 03:28 AM
