1. Anis Serri's Avatar
    I bought the dre beats and they aren't loud but when i use it with my other devices it woks perfect and loud?
    02-09-2014 03:21 PM
  2. Solrighal's Avatar
    Your Note 3 is trying to tell you something. Buy better cans mate.
    Sent from my SM-N9005
    crester likes this.
    02-09-2014 05:34 PM
  3. shanghaichica's Avatar
    I tried my Solo HD with the note 3 the other day and they sounded fine. I didn't turn then up to the max volume like I do when outside. Maybe I'll take them with me on the way to work tomorrow morning and see how loud they get.
    Posted from my galaxy note 3
    02-09-2014 06:17 PM
  4. officialclar's Avatar
    Try adapt sound.
    02-09-2014 09:00 PM
  5. Anis Serri's Avatar
    What do u mean better can???
    02-10-2014 07:16 AM
  6. Anis Serri's Avatar
    What's that?
    02-10-2014 07:17 AM
  7. shanghaichica's Avatar
    He means get a better pair of headphones. He thinks that beats are rubbish.
    02-10-2014 09:10 AM
  8. Anis Serri's Avatar
    Lololol they actually work amazing with other devices
    02-10-2014 09:26 AM
  9. z06mike's Avatar
    Go to settings >device >sound and choose adapt sound.
    Sent from my SM-N900V using Tapatalk
    02-10-2014 12:04 PM
  10. c1971ace's Avatar
    My Solos HDs work great on my 3....
    02-10-2014 01:06 PM
  11. Solrighal's Avatar
    Yeah Anis, sorry. I wasn't very helpful there. I'm a bit of a headphone geek. Anyway, what app are you using that's causing your level problem? Adapt Sound can help a bit but if there's an appreciable drop in output level compared to your other devices then it's more likely to be something else that's causing the problem. Keep us updated.
    02-10-2014 01:20 PM
  12. JellyBeanGurl's Avatar
    Double post.
    Sent From My Samsung Note 3 using Tapatalk
    02-10-2014 06:31 PM
  13. JellyBeanGurl's Avatar
    My husband has been looking for quality headphones. He picked up the Bose and was extremely disappointed. Any suggestions?
    02-10-2014 06:31 PM
  14. Solrighal's Avatar
    That's a big question. Is he looking for cans that enclose the ears, sit on the ears or sit in the ears? Is noise-cancelling a must? If they're for music what kind if music? Biggest of all, how much is he prepared to spend? Finally, what did he not like about the Bose headphones?
    Sorry for all the questions but there are so many different products out there. http://www.head-fi.org is the place to go for advice like this. I can give advice here but I'm only one person and by no means am I an expert.
    02-10-2014 06:46 PM
  15. Junior Bonetti's Avatar
    Because the device (note 3) and the BEATS have separate volumes. I thought the same thing when i hooked them up to my Galaxy s4, then I used the volume on the headphones.. it's not the same as the phone volume. Turn the phone all the way up then use the headphones to adjust to your lvl.
    02-13-2014 07:09 PM
  16. shanghaichica's Avatar
    What app do use to play your music?
    The volume controls on my Solo HD's don't work with my note 3. I'm using player pro.
    02-14-2014 01:48 AM
  17. Peaches36's Avatar
    I use Skullcandy Ink'd.. $30 and the bass sounds great.. Expensive doesn't always mean great.
    Sent from the yummy gum drop GN3..
    02-14-2014 10:15 PM
  18. Jeric Gorospe's Avatar
    Dissapointed about the music. It is working properly but the volume is low. I am using dr dre solo hd and the music is not loud as the iphone/itouch
    jggorospe GALAXY NOTE 3
    02-15-2014 12:28 AM
  1. contacts not showing up in phone app contacts
    By Daniel Saucedo1 in forum Google Nexus 5
    Last Post: 08-19-2016, 11:29 AM
  2. Replies: 5
    Last Post: 02-18-2014, 07:18 PM
  3. Is it just me or do Samsung phones have a lot of issues?
    By rockitdog23 in forum Samsung Galaxy S4
    Last Post: 02-14-2014, 06:54 AM
  4. Samsung Galaxy 4: Deleting calls from call list
    By benjerman1 in forum Samsung Galaxy S4
    Last Post: 02-09-2014, 02:28 PM
