1. dpbayly's Avatar
    Hi all I love the phone, I've had the Note 1 and Note 2 and I've never had this issue before.
    It sometimes even though it shows good wifi connection when I click on browser or anything else that needs the connection it just does nothing and then comes up no connection all the time showing full signal wifi connection and to get it working sometimes if I just reload the page it will come back to life but failing that if I disable and enable the wifi it works again what normally happens when it doesn't work the upload /download arrows showing the phone connection working show the phone uploading info (green arrow) but I get nothing downloading orange arrow:
    I have the Auto switching turned off and that doesn't help and it does it both at work and at home connections.
    Another thing It occasionally does (I don't know if its related) but when leaving the wifi connection the phone should switch to mobile data connection for some reason it doesn't and next to the signal bar where the connection status normally is theres nothing and again when I selects the browser it displays no connection and to get it working again I have to restart the phone or if I select flight mode then de select flight mode it comes back.
    Has anyone else experienced this or does anyone know what my issue is and how I might sort it?
    02-13-2014 06:14 AM
  2. zocster's Avatar
    Hi there, welcome to Android Central, which firmware are you running on your note? I have just loaded 4.4.2 through odin on my one and it seems fine, no issues with wifi at all.
    02-20-2014 12:18 AM
  3. TheMacs's Avatar
    Welcome!
    The poor wi-fi conntection you're experiencing is well documented.
    Unfortunately there is no confirmed 100% fix. Lots of theories, some help, others don't.
    Review the threads and you can try each one at a time. Good luck. (None have worked for me yet. )
    02-20-2014 12:06 PM
  1. Problem with Google Drive App on Asus Memo Pad 7
    By wigwam3 in forum ASUS MeMO Pad HD7
    Last Post: 02-14-2014, 07:20 PM
  2. S4 i9500 (calling and texting issues)
    By egosha osagiede in forum Samsung Galaxy S4
    Last Post: 02-13-2014, 08:02 PM
  3. I made a stupid problem
    By Jr Lagos in forum Google Nexus 7 (2013) Accessories
    Last Post: 02-13-2014, 04:27 AM
  4. some videos don't appear on YouTube mobile app - why?
    By xstinkyx in forum Android Apps
    Last Post: 02-13-2014, 04:09 AM
  5. I made a stupid problem
    Last Post: 02-13-2014, 12:29 AM
