1. marktika's Avatar
    I was checking if there are any new software updates for my Note 3, i wen to settings>software updates>check for updates. Then a window appeared stating "Your device has been modified. Software updates not available."(i dont know how to post a screenshot here).
    My device got rooted when i brought it to a technician cause it was locked on a specific provider.
    What am I supposed to do? Can i still be able to update my phone? Update to Kitkat too?
    02-15-2014 02:38 AM
  2. UJ95x's Avatar
    You'd have to flash a stock firmware file to get rid of the modified status. That will probably lock it to the original carrier though.
    Sent from my XT1056 using the Android Central App
    02-15-2014 03:03 AM
  3. marktika's Avatar
    How am i supposed to do that? Sooryy not much of a techie.
    02-15-2014 03:19 AM
  4. UJ95x's Avatar
    1) Download Odin to your PC
    2) Download 7zip as well
    3) Open 7zip, and use it to unzip the Odin file you downloaded
    4) Now open the actual Odin program
    5) Download a stock firmware file for your exact model number. You can get these on either sammobile or samsung-updates.com
    6) In Odin, hit PDA if you're using version 3.07 or earlier. AP if it's 3.09
    Now look for the firmware file you downloaded, uncheck F. Reset time, and hit start
    02-15-2014 03:24 AM
  5. marktika's Avatar
    Thnks! Its so drtailed. After that what happens? Will my firmware be genuine again? And my phone will lock to its previous carrier?
    02-15-2014 03:30 AM
  6. UJ95x's Avatar
    After that, if it passes, it'll be back to it's original state, so make sure you back everything up before doing it.
    Not 100% sure if it'll lock to the original carrier, but if you had to modify it to get it unlocked in the first place, you might have to do it again
    02-15-2014 03:32 AM
  7. marktika's Avatar
    Thanks! Is there not a way that i can upgrade to kitkag with my phone status right now?
    02-15-2014 03:33 AM
  8. marktika's Avatar
    can you post a website where ic an download odin? plss. there are plenty of Odin when i serched google cant pick the right one. haha
    02-15-2014 05:05 AM
  9. chustle925's Avatar
    How did you or the technician root the phone?
    02-15-2014 07:44 AM
  10. UJ95x's Avatar
    http://forum.xda-developers.com/show....php?t=2189539
    Sent from my Galaxy S4 running Slim Bean 4.3
    02-15-2014 08:18 AM
  11. marktika's Avatar
    Really dont know, the purpose of the root was just to open line my unit. Why?
    02-15-2014 08:22 AM
  12. marktika's Avatar
    Thanks man! I just found out that you're reply in almost all of my threads! Thanks! Bare with my innocence in this technology. Haha
    02-15-2014 08:24 AM
  13. UJ95x's Avatar
    I get around
    02-15-2014 08:31 AM
  14. Golfdriver97's Avatar
    I think I got my version of Odin off XDA too. Haven't used the 3.09 yet, as I have 3.07, and for me it works just fine.
    02-15-2014 09:56 AM
  15. UJ95x's Avatar
    I'm still using v1.85 lol
    02-15-2014 09:58 AM
  16. Golfdriver97's Avatar
    Oh, I have that version too. Lol...
    02-15-2014 10:23 AM
  1. Replies: 13
    Last Post: 02-26-2014, 02:55 PM
  2. help HTC one bought it fairly used
    By Osuagwu Darlington in forum HTC One M7
    Last Post: 02-17-2014, 01:29 PM
  3. Replies: 7
    Last Post: 02-15-2014, 03:04 PM
  4. Replies: 3
    Last Post: 02-15-2014, 01:28 PM
  5. help with HTC one
    By Osuagwu Darlington in forum General News & Discussion
    Last Post: 02-15-2014, 11:38 AM
