1. tsantil's Avatar
    Guys i rooted my phone a month ago i have galaxy note 3 sm-n9005.i decided to unroot it and the tragedy began.i do the process step by step but when the program finishes in the after hidden is written in the box it says fail because of size error do you know what i can do?please help
    02-20-2014 10:01 AM
  2. wizzrah's Avatar
    What program did you use?
    02-20-2014 10:31 AM
  3. tsantil's Avatar
    odin
    02-20-2014 11:20 AM
  4. tsantil's Avatar
    please guys help me i can't use my phone
    02-20-2014 02:07 PM
  5. Alain_A's Avatar
    factory reset!!!!!!
    I don't know if it would help tho.......just a thought
    02-20-2014 03:04 PM
  6. UJ95x's Avatar
    What exactly did you do in Odin? There is an unroot option within the superSU app that you could have used
    Sent from my Galaxy S4 running SlimKat 4.4.2
    02-20-2014 03:06 PM
  7. H3aTeRzz's Avatar
    The suspense is killing me....
    02-20-2014 07:44 PM
  8. Alain_A's Avatar
    yeah waiting for outcome....
    H3aTeRzz likes this.
    02-20-2014 07:53 PM
  9. chriscw81's Avatar
    If you can get into download mode you can easily get you phone back up and running with Odin. Read and follow this carefully. ...
    http://forum.xda-developers.com/show....php?t=2483380
    sent from tapatalk....probably while pooping.
    02-21-2014 05:29 AM
  10. tsantil's Avatar
    guys look i just searched how to unroot and i found that i have to go to odin and select a stock firmware .i did this but it didn't work
    02-21-2014 07:02 AM
  11. Alain_A's Avatar
    have you tried what he said............>There is an unroot option within the superSU app that you could have used
    Also to unroot I rememner to see a couple of good video about that subject....I think using something like Kingo
    02-21-2014 09:17 AM
  12. tsantil's Avatar
    ok guys here is an update of my situation:because the phone was stuck in recovery mode and i couldn't do anything with kies because my phone was rooted i decided to reroot (if it's called like that) my phone.ok i opened it i went to super su like said and i unroot it.then i also did the return to factory procces i rebooted my phone and when i opened it i was saying samsung keyboard not working .also when i tried to update to see if i could fix the problem i got message saying your device has been modified no update.so now i am stuck with a phone that can only call and nothing more.I would apreciate it if you help me thanks guys!
    02-21-2014 09:31 AM
  13. UJ95x's Avatar
    Can you use emergency recovery in Kies?
    Sent via Tapatalk
    02-21-2014 11:10 AM
  14. chriscw81's Avatar
    You may want to try what this guy said to do. I think it may have worked for him ;-)
    02-21-2014 02:54 PM
  1. Help, note 3 unlocked now what?
    By ruckhard in forum AT&T Samsung Galaxy Note 3
    Last Post: 02-21-2014, 01:50 AM
  2. Help...spilled Kiwi Juice on my Galaxy S4
    By GalaxyPeasant in forum General Help and How To
    Last Post: 02-20-2014, 08:12 PM
  3. Samsung SIII Mini not working, help!
    By anamelle in forum Samsung Galaxy S3 Mini
    Last Post: 02-20-2014, 09:19 AM
  4. help understanding android file structure
    By m147 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-20-2014, 03:19 AM
