1. Fiona A's Avatar
    I have a brand new Note 3 which has started making this annoying 3 tone noise. Sometimes it won't stop till i turn the phone off & other times it will just do it for 30 seconds or more/less, & stop on its own. I just worked out its the same tone as when you hang up from a call. It happens anytime. I could be on a call or just be looking through the phone and it will happen!
    I have just had this phone replaced after issues with the last one which was also brand new! I want to avoid sending it back again if there is a way i can solve the problem myself.
    I have taken the battery out restarted it but it still happens.
    Any help would be appreciated.
    Thanks.
    02-20-2014 11:51 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! I can't tell you what the tone means, but I remember someone else posting about this, and it seemed to be related to the NFC (Near Field Communication) chip. Try going to Settings>Wireless & Networks, and unchecking NFC. You don't need it on anyway, unless you use your phone to transmit data using a "bump" feature (i.e., bringing your phone into close proximity with another phone or device to transfer info).
    02-21-2014 12:09 AM
  3. Fiona A's Avatar
    Ok Thanks B.Diddy i have turned off NFC. Hopefully that has solved this annoying problem!
    02-21-2014 02:39 AM
  1. Note 10.1 LTE Version Coming to Verizon Feb. 27?
    By JSun in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 02-21-2014, 04:29 PM
  2. Nexus 4 Random Reboots
    By 1210saad in forum Google Nexus 4
    Last Post: 02-21-2014, 08:19 AM
  3. 8.4 Note PRO
    By Nychotxxx in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 02-21-2014, 08:09 AM
  4. Anyone managed to get vanilla Android running on a Note 3 yet?
    By StuartMcDowell in forum Samsung Galaxy Note 3
    Last Post: 02-20-2014, 05:58 PM
  5. Help! Note 2 bootloop no recovery
    By MBrar15 in forum Samsung Galaxy Note 2
    Last Post: 02-20-2014, 04:19 PM
