1. Jaco Wilters's Avatar
    Hi guys. I did the new firmware update on my gear yesterday and now my S Health does not pick up my Gear. I scanned for the Gear and it does not pick it up at all, even though my Gear is already connected to my Note. Can anyone help?
    02-24-2014 11:39 AM
  2. clitrenta's Avatar
    I've had a few issues myself with the Samsung Apps acting dumb on the Gear. Just try what I did. It might work. Go into Manage Apps (in settings) on your Note. You can't uninstall it but you CAN uninstall the update. Do that and then do a force close. Then re-install the update to S Health. See if that might do the trick.
    02-24-2014 02:29 PM
  3. Jaco Wilters's Avatar
    Hi. It does not seem that an update was on done on S Health. The update I am referring to was on my Gear Firmware. There is no option in apps manager to uninstall any update at the moment. I have forced a stop and restarted my Note, no success. Any more ideas?
    02-24-2014 10:11 PM
  4. floridarick's Avatar
    Do you have the option to "Send to S Health" on the drop down menu on the pedometer app on you Gear?
    That is what I have to do to get my S Health app on my Note3 to get the pedometer & workout info from the Gear........
    02-25-2014 03:05 PM
  5. Jaco Wilters's Avatar
    Hi guys, managed to sort the issue out. I had to delete and reconnect my gear. Downside is that I basically had to setup my gear from scratch.
    02-27-2014 01:03 PM
  6. clitrenta's Avatar
    Yah, I was actually going to suggest that. Whenever an app gives you issues like that, you usually end up resetting the Gear. A pain but certainly better than resetting the phone. FYI: there are a few notification types that just won't clear from the Gear. The only way I got rid of them was to reset my Gear. I then just turned off those notifications and hopefully Samsung will fix that in a future update. Which ones I've noticed this from so far? - CNN, Missed Calls, and possibly Hangouts. Also, you can only respond to text messages if you are using the default messaging app on the phone. If you are using ChatOn or Hangouts, there is no way to respond, just read. These are all just annoying little issues that I hope Samsung clears up in the near future because I really like this watch and plan to continue to use it for a long while, especially since I'm not overly crazy about the Gear 2 design.
    02-27-2014 01:52 PM
  7. atom chik's Avatar
    Guys, i am having the same issue, i have a note 3 and i was assuming that the s health and the gear manager worked properly only on galaxy s5. Did resetting of the gear fit work for s5 or some other samsung phone? I would prefer to not reset the gear in case it is not going to work. Thank you very much!!
    04-14-2014 07:23 PM
  8. snouf's Avatar
    i did many times reset factory of the watch & phone, and yet i still can't get the pedometer to sync...
    gear 2 lite & s5 mini
    10-16-2014 03:59 PM
  9. dreamur's Avatar
    Got my Note 4 with KK4.4.4 and it totally fixed the bluetooth connectivity issue!
    10-28-2014 07:27 AM
  1. Nexus 5 not saving application defaults
    By CTRK Chaitanya in forum Google Nexus 5
    Last Post: 09-08-2016, 10:41 AM
  2. Replies: 1
    Last Post: 02-24-2014, 04:16 PM
  3. Replies: 1
    Last Post: 02-24-2014, 10:36 AM
