Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By lattemaker
    Default Help with transfer from S4 to Note 3, what's the best method?
    Hi people! I currently have a Galaxy S4, rooted via method. The S5 fails to impress me, and in several ways is actually a downgrade from my S4, so I'd like to use my JUMP! upgrade on a new Note 3 instead. With T-Mobile, I need to back up all my stuff before I upgrade. I need to wipe my S4 and unroot it. I can handle that. I also need to root my new Note 3, and looks promising. It might even be the same thing I did to my S4. So, here's what I don't get. I know when I turn on my new Note 3 and sign in Google Play will automatically redownload all my apps, minus a small handful I got online, but will it automatically download my app data too?
    I have root on my S4 now, and my Note 3 will be rooted, so with over 600 apps, what is the best way to transfer all (or as much as possible) of my apps and data from my S4 to my Note 3, without needing both devices at the same time? I'd rather not use an app that backs up and restores everything because it will install all my apps outside of Google Play and they won't update automatically. Since Google Play will reinstall all of my apps anyways, is there some root tool I can use to just back up my app data for all my apps, then restore that data to the newly downloaded apps on my new phone? Is that even needed? Will Google Play back up my app data automatically? If Google Play can handle everything, then is there a way to manually back up all my app data right before I wipe my S4?
    Thanks so much!
  2. #2
    Default Re: Help with transfer from S4 to Note 3, what's the best method?
    You have 600 apps on your phone? You lost me at this point. .
    Sent from my SCH-I545 using Tapatalk
  3. #3
    I'm not sure this works but try Samsung Kies. I just don't know if it will work for rooted devices.
    FutureKix likes this.
    Okay! I'll look into that, thanks.
  5. #5
    Samsung has a pretty decent app for this, in the Google Play Store - its called Samsung Smart Switch Mobile.
    You will need to install it on both your S4 and your new Note 3, and let it do its magic.
    It was pretty decent when I went from my Note 2 to the Note 3.
    It mucked up some things, but this is where Helium came to the rescue, since it had all my apps and settings backed up.
    Then there is always Kies, but that's been a hit and miss for me.
    Quote Originally Posted by DrSavant View Post
    Hmm. That's a good idea. I suppose I could back up my data, unroot, and still use the Samsung transfer app. Did it transfer app data? Did it allow Google Play to update apps automatically? Thanks. 😃
  7. #7
    Why unroot?
    Yes, it transferred data and installed apps from the play store
    Sent from my SM-N900W8 using Tapatalk
    Thanked by:
  8. Thread Author  Thread Author    #8
    If I bring my S4 into the T-Mobile store rooted they might fight me on the JUMP! upgrade, arguing that I have to pay the $175 deductible as rooting the device voids the warranty. Much simpler to avoid the issue altogether and just unroot the phone before bringing it in. The "custom" flag was set off, but not the "root" one, or something like that. I just know when I rooted it the online guide said this method was "warranty safe" so I can unroot it without T-Mobile ever knowing it was previously rooted.
    Why unroot?
  1. WTT:BB Q10 Mint with accessories for Nexus 5
    By sgt50 in forum Sold / Archived Marketplace Threads
    Last Post: 03-08-2014, 04:05 PM
  2. Does the new Galaxy S5's exterior look cheap and tacky?
    By yourphonemyphone in forum Samsung Galaxy S5
    Last Post: 03-08-2014, 03:58 PM
  3. my Samsung Galaxy s4 device status "Custom"
    By Kelvin Paulino in forum T-Mobile Samsung Galaxy S4
    Last Post: 02-27-2014, 02:29 PM
  4. Price S4
    By Chilliee in forum Samsung Galaxy S4
    Last Post: 02-25-2014, 03:09 PM
B
