Hey i want to try your ROM.
im not sure if mine's SM-N9005, how do i check? And can you please teach me how to put that ROM in my phone. Im afraid my phone will malfunction. Thank you!
You can check by going into Settings> General> About Device and it will be under Model Number.
First you will need to root & then flash a custom recovery.
This is Done on the Pc
To Root check your variant then download the Cf - auto root for that specific version. (Xda Developers)
Download kies 3 (used for drivers)
Download Odin (used to flash)
Put you phone into download mode by turning off, then holding Power> home> volume down. Your in download mode then press volume up to continue.
Connect to pc/laptop via usb and open odin, depending on the version it will either have PDA or AP, click in the box it will open a location folder> locate your file Cf - auto root> hit open> then make sure the box is ticked beside either PDA or AP> hit start> once finished there will be a green box with pass.
Then you have to do the same process with the custom recovery.
Once you have your custom recovery, you can download the ROM of your choice to your sd card> enter recovery by Turning off then press and hold power> home> volume up. You will have to factory reset, wipe cache, go into advanced and wipe dalvik cache. Then install zip, locate your file will be on external sd and then install.
Hope this helps and if unsure, watch a few videos to see the process.
Xda developers is the site I use for everything root and rom.
