Page 1 of 3 123 LastLast
Results 1 to 25 of 66
Like Tree1Likes
    Default LTE Doesn't Work on my Samsung Galaxy Note 3
    I bought a 4G SIM Card with 4G provider.
    On my phone I have no LTE option, but in an HTC One of a friend with the same SIM card, he has the LTE option and the 4G symbol shows up.
    On my phone the 4G symbol or the LTE network option never show.
    Bought the phone here: Samsung Galaxy Note 3 Region Locked Smartphone - Black: Amazon.co.uk: Electronics
    Did the latest firmware update through KIES 3 yesterday. Kies | SUPPORT | SAMSUNG UK
  2. #2
    msndrstood's Avatar
    Posts
    ROM
    Stock JB 4.1.2
    Default re: LTE Doesn't Work on my Samsung Galaxy Note 3
    I believe you have a Chinese clone international model which does not have 4G LTE radios so you would not be able to access LTE service no matter what sim card you put in the phone.
    Someone else may have more info but I believe this is correct from my Google search.
    Sent via The Big, Bad, Beautiful Note 3
    What?!...I'm msndrstood.
    Sent via Note 2
  3. #3
    What model is the device? Carrier version or a 900/9005 model? Though 9005 models support 4G, it's international 4G and not carrier or USA compatible. The 900 has no LTE radios built in it.
    Sent from my SM-N900P using Tapatalk
  4. #4
    Quote Originally Posted by G3MINI_N3RD View Post
    As said here OP you bought the 900...so no LTE radios are in the phone.. Hence why you are not getting LTE.
    Sent from my T-Mobile Note 3 using AC Forums.
    Attached Thumbnails Attached Thumbnails LTE Doesn't Work on my Samsung Galaxy Note 3-1393436368195.jpg
    Sent from my T-Mobile Note 4 using AC Forums.
  5. #5
    Be careful if you choose to buy a new one, make sure it has lte on the band(s) and that your carrier supports
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
  6. #6
    Quote Originally Posted by Almeuit View Post
    Definitely went dunce mode not seeing the link. Yeah its an international factory unlocked 900 model. That model has no LTE radios.
    It's an N9005, on the internet it says everywhere it has 4G and LTE. I don't see where's the problem...
  8. Thread Author  Thread Author    #8
    And I'm in Ireland in Europe. I told you guys the SIM card worked on an old HTC One bought here.
  10. #10
    I have the N9005 Version too (UK) and never see the LTE or 4G sign only HSPA+ my area hasn't got 4G yet I don't think 4G has only recently started rolling out in the UK a lot of cities don't have it yet only the bigger cities, only some parts of Northern Ireland have it have you checked with your network provider if your area has it? The only other thing is I can think of is have you got mobile data switched on?
    Sent from my SM-N9005 using AC Forums mobile app
    Attached Thumbnails Attached Thumbnails LTE Doesn't Work on my Samsung Galaxy Note 3-1393442750882.jpg
  11. Thread Author  Thread Author    #11
    Quote Originally Posted by JordanN9005 View Post
    Tried with Mobile Data On or Off...nothing
  12. #12
    Post screen shots of your network screen, where you can access the apn. It's under more settings also post the about device screen shot.
    Sent from my SM-N900V using Tapatalk
  13. Thread Author  Thread Author    #13
    Here it goes:
    LTE Doesn't Work on my Samsung Galaxy Note 3-screenshot_2014-02-27-08-11-28-1-.jpgLTE Doesn't Work on my Samsung Galaxy Note 3-untitled.jpgLTE Doesn't Work on my Samsung Galaxy Note 3-screenshot_2014-02-27-10-19-14-1-.jpgLTE Doesn't Work on my Samsung Galaxy Note 3-screenshot_2014-02-27-10-19-26-1-.jpgLTE Doesn't Work on my Samsung Galaxy Note 3-screenshot_2014-02-27-10-19-46-1-.jpgLTE Doesn't Work on my Samsung Galaxy Note 3-screenshot_2014-02-27-10-19-52-1-.jpg
  14. #14
    I think you may have actually got a replica where did you get the device from? Your missing LTE in the network mode part section here is what mine looks like...
    Attached Thumbnails Attached Thumbnails LTE Doesn't Work on my Samsung Galaxy Note 3-1393509257756.jpg
  15. Thread Author  Thread Author    #15
    Bought from here: http://www.amazon.co.uk/gp/product/B...r-21&m1k=vb_ac
    Do you think Amazon would cheat the clients? So should I ask a refund to Amazon?
  16. Thread Author  Thread Author    #16
    I have a strange feeling that if I change the network provider I'll have 4G...
  17. #17
    Quote Originally Posted by Kyo Kusanagi View Post
    Did you buy it ship and sold by Amazon? Or buy it through a third party on Amazon? Either way if it advertised 4GLTE and you don't have 4GLTE then contact the seller for a return
  18. #18
    Only EE and a couple others have started rolling out 4G in the UK, what network is it your using?
  19. Thread Author  Thread Author    #19
    Third party on Amazon. Anyway if i'll try first with another network operator befor asking for a refund.
  20. Thread Author  Thread Author    #20
    I'm using Meteor from Ireland. In Ireland Vodaphone, 3, and O2 also support 4G already.
  21. #21
    Ok good luck
  22. #22
    Well for 4GLTE, it should say lte. Here is another screen
  23. Thread Author  Thread Author    #23
    So you say if the option should always be there in the menu, even if there's no 4G signal available?
    Maybe rooting the phone and using this app? https://play.google.com/store/apps/d...gnalinfo&hl=en,
  24. #24
    Correct, the option should be in the menu if the phone is capable of lte, regardless of if your carrier or location has lte.
    You can try that app, I doubt it would show any hidden lte radio though.
    Personally if it was advertised with lte, the LTE should be accessible without root.
  25. #25
    msndrstood's Avatar
    Posts
    ROM
    Stock JB 4.1.2
    Quote Originally Posted by dpham00 View Post
    Well for 4GLTE, it should say lte. Here is another screen http://img.tapatalk.com/d/14/02/27/pymytete.jpg
    This.^^^^ I was going to mention that but the OP seems determined that this is an LTE phone, which I'm pretty sure it's not.
    Sent via Note 2
  1. LG G2: dead zone on screen
    By Virgil52 in forum LG G2
    Last Post: 11-24-2014, 08:06 AM
  2. cloud print. print spooler on kitkat
    By thekC in forum Samsung Galaxy S4
    Last Post: 07-31-2014, 02:53 AM
  3. Need a plan for my Nexus 5
    By Zendroid1 in forum Google Nexus 5
    Last Post: 03-15-2014, 05:28 PM
  4. Samsung Galaxy S4 and memory card problems
    By bigjay2100 in forum General Help and How To
    Last Post: 02-27-2014, 10:32 PM
  5. Why do the software updates make my phone worse?
    By rcwalker_07 in forum Droid RAZR MAXX
    Last Post: 02-27-2014, 07:33 PM
