Results 1 to 8 of 8
    Default Help with permission error.
    I have a rooted note 3 running a custom ROM called Sweet (I think) my issue is I have an issue where apps can't write to the internal storage.
    I've searched around and people mentioned adding a line to platform.xml, I done this but there's no difference.
    Any ideas?
    Also, the app BlockLauncher can't run scripts due to Knox, is there anyway around this?
    I posted in XDA but they don't seem to care unless you're a dev!
    Thanks.
  2. #2
    Johnly's Avatar
    Retired Moderator
    Posts
    Global Posts
    10,995 Global Posts
    Carrier
    AOSP, & stock.
    Default Re: Help with permission error.
    What version of Android, and where are the apps writing data?
    4.4.2 KitKit, and I was simply trying to rename a file within /sdcard/Download, but no Apps will do it.
    I don't have an SDCard in just internal storage, so the external_write suggestion I've seen doesn't apply, right?
  4. #4
    Johnly's Avatar
    Retired Moderator
    Posts
    Global Posts
    10,995 Global Posts
    Carrier
    AOSP, & stock.
    Has that ROM let apps write correctly before?
    I'm not sure it did, I'm pretty new to Android (recently switched from iOS) so I'm still getting to grips with rooting.
    I don't think it let me after installing the ROM, but as far I can remember it did work before.
    I've finally got everything set up perfect, looks like I'll be switching ROMS.
    I just installed a completely different ROM and still getting the same problem :-( nothing can write to storage/emulated/0/
    Is stock firmware for BTU Note 3 4.4.2 available anywhere? UK version that is.
  7. #7
    Johnly's Avatar
    Retired Moderator
    Posts
    Global Posts
    10,995 Global Posts
    Carrier
    AOSP, & stock.
    Quote Originally Posted by LiamHing View Post
    What is the model number of your note? Do you want to go back to stock?
  8. Thread Author  Thread Author    #8
    Quote Originally Posted by Johnly View Post
    I'm pretty sure it's the SM-N9005 International (UK) Unlocked/Unbranded, I don't think 4.4.2 Stock Firmware is out yet.
  1. Using link scripts with /system
    By Toucan4267 in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 04-27-2014, 06:08 PM
  2. Disapointed with KitKat
    By sparker781 in forum Android 4.4 KitKat
    Last Post: 03-09-2014, 11:31 AM
  3. Android TF701F problem with keyboard dock
    By Richard Dallaire in forum ASUS Transformer Pad TF701
    Last Post: 03-02-2014, 10:01 AM
  4. Replies: 7
    Last Post: 03-01-2014, 04:05 PM
  5. Issues with Kingo seeing my Note 3
    By thedarkwolf25 in forum Verizon Samsung Galaxy Note 3
    Last Post: 03-01-2014, 01:51 PM
