I was trying to root my Note 3 yesterday. I followed all directions and read through the instructions step by step before beginning. I was in the middle of flashing (I believe) when the power flickered. (Maybe trying this in the middle of a snow day wasn't the best idea). Anyway, I now have the "go to recovery mode in Kies" screen on my phone. I tried doing the recovery in Kies, as well as the emergency recovery, and neither worked, so I tried several of the instructions that say to flash a custom rom. Those go all the way through the steps and flash FAIL at the very last part. I'm not totally sure what to do. Upon trying the Kies one more time, I saw (again) where it said to boot into recovery. I double checked, and from what I understand, Recovery has several options that you can scroll through with the volume buttons, but Odin mode is, well .. Odin mode. Is this correct? Could the Kies recovery have not worked because I actually wasn't in recovery mode on my phone? If that's the case, how do I get to recovery mode? I've tried the button hold to reboot, and it either goes to the "go to recovery mode in Kies", or to the Odin. After trying the Kies recovery, a note pops up that says it had to stop recovery due to an error on my Note 3, so I figured maybe it needed to be in the recovery mode and not Odin. I found a site online that said I could download the ADB things for my computer to enter recovery mode using the command prompt, and that didn't work either - I can't get my computer to recognize the device. (It recognizes it initially, and says drivers are installed and ready to use, but about halfway through the ADB process, there is a step where I'm supposed to go to control panel and find my device and update drivers - I can't find it then).
Does anyone have any suggestions? I was hoping that if I could figure out how to actually get my phone into recovery mode. Any suggestions would be so much appreciated. I'm a stay at home mom and this is my only phone (no landline), so I need a working phone! Thanks in advance.
