1. Anil Ghatikar's Avatar
    Hi,
    I have not used Galaxy Gear but Sony smart watch , Head set as will as pebble.
    I have noticed that when I first pair them I get a prompt about switching of accessibility features and my most of the fancy features such as stay on , dual window, air view etc.) switch off completely
    Any idea does it happen with galaxy gear watch or for that matter the new ones .
    If not it may be a big plus point for getting the new gear 2 or fit
    Anil
    03-05-2014 05:29 AM
  2. clitrenta's Avatar
    Hi,I have not used Galaxy Gear but Sony smart watch , Head set as will as pebble. I have noticed that when I first pair them I get a prompt about switching of accessibility features and my most of the fancy features such as stay on , dual window, air view etc.) switch off completelyAny idea does it happen with galaxy gear watch or for that matter the new ones . If not it may be a big plus point for getting the new gear 2 or fit Anil
    I use the Note 3 and Gear 1 and I have never gotten any such notice. My Note works exactly as it should regardless.
    03-05-2014 07:32 AM
  3. DrSavant's Avatar
    No such warnings here either - Note 3 and original Gear.
    03-05-2014 09:36 AM
  4. Anil Ghatikar's Avatar
    Thanks Guys . Now it is clear why samsung says the watch is compatible with only samsung devices. It uses something different than accessibility framework
    03-07-2014 06:32 AM
  1. T-Mobile Galaxy Note 3 KitKat Update
    By lccurtis1 in forum Android 4.4 KitKat
    Last Post: 03-05-2014, 09:34 PM
  2. spoof device for google play question
    By StoneRyno in forum HP Touchpad
    Last Post: 03-05-2014, 04:22 PM
  3. Notifications only on wifi - why?
    By nagellack in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-05-2014, 03:28 AM
