Results 1 to 10 of 10
    mactruck's Avatar
    Posts
    Global Posts
    87 Global Posts
    Default Another battery thread(forgive me)
    Am I getting greedy by wanting more?
  2. #2
    Default Re: Another battery thread(forgive me)
    Under 2.5 hrs of screen on time seems fairly poor, but I can't tell from those stats why it might be that way. It looks like your cell signal is usually fine, so poor signal would be causing drain. I don't see any intensive gaming being done. Are you running stock Android?
    mactruck's Avatar
    Posts
    Global Posts
    87 Global Posts
    Quote Originally Posted by B. Diddy View Post
    I'm using GEL which I assume causes some battery drain.
    I read on here about nonstock wallpaper so I use a wallpaper that is available on the phone already.
    My signal does get poor sometimes here at work, but not terrible. I maintain LTE 99.9% of the time.
    For this test, I had my brightness all the way down.
  4. #4
    Did you also modify it to be always listening for "Ok Google"? That might drain the battery a little faster.
    Have you tried going back to TouchWiz, or perhaps trying some other launcher like Nova?
    mactruck's Avatar
    Posts
    Global Posts
    87 Global Posts
    I'll try switching back to action launcher and do another test. I assumed GEL was the issue, but never saw it pop up. Makes sense it caused the screen issue.
  6. #6
    Yes it is definitely a cause of the battery drain. You're awake time was over 5 hrs but screen on was only 2.5
    Sent from my SM-N900V using Tapatalk
  7. #7
    Give us the screen shot "view time held awake" If it's some 3rd party app that's keeping your device awake then just delete it and then reinstall it to see if the battery gets better or just leave it uninstall. If it's an app that came with the device, try restarting the phone to see if the battery gets better.
    Btw, your signal is fine because i had worse signals then you from time to time but my battery on drop a few percent when I don't use it.
  8. Thread Author  Thread Author    #8
    mactruck's Avatar
    Posts
    Global Posts
    87 Global Posts
    This is from overnight. I put it down at 95% and woke up to it being 85%. My signal at home seems terrible.
    Android OS is holding it. Ideas why?
  9. #9
    Turn off wifi when you don't use it. I don't know about the kernel though. It keeps my phone awake too but my battery isn't as bad as yours
  10. #10
    Always listening should not impact battery life in a substantial way, at least not s voice. I have tried enabling and disabling it and didn't notice much difference.
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
  1. Let me help you root!!!!
    By Upstreammiami in forum Samsung Galaxy Note 3
    Last Post: 10-19-2016, 11:32 PM
  2. T-Mobile Note 3: Android 4.4.2 (KitKat) update problems and issues thread
    By srkmagnus in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 11-18-2014, 04:48 AM
  3. Replies: 4
    Last Post: 03-05-2014, 05:33 PM
  4. Yet another water damage thread.
    By cali2385 in forum Samsung Galaxy S3
    Last Post: 03-05-2014, 06:14 AM
  5. 100% to 95% battery
    By runwithme in forum LG Optimus G Pro
    Last Post: 03-05-2014, 03:57 AM
