1. lukifell's Avatar
    I dropped my Note 3 on the floor. It was like the lamest drop in history, maybe less than half a meter, so there was no visible damage. Yet after I got home, I realized it wouldn't charge anymore. I swapped out the battery, tried multiple chargers. No luck. I already knew it wasn't anything like that though, since my PC no longer recognized the phone via USB. So I took it to a Samsung shop. I live in China, and since I bought the phone in Hong Kong, they said I'd have to mail it to there to get fixed.
    Well, maybe this was a dumb move, but I didn't wanna wait. I took it to a private phone shop, and they took it apart. Over one hour later, they tell me that the module that handles the charging of the phone is damaged. Does that sound right? Internal chip damage from a simple short drop? Are these phones really this fragile?
    What's the best way go about fixing it? They said the new part plus labor would be around 80$. I don't really care about the price -- just want my phone working 100% again. Any thoughts on this?
    03-05-2014 10:25 PM
  2. dpham00's Avatar
    Could be, it really depends on how it dropped. It it dropped bottom first onto concrete, maybe.
    Did you have a case?
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    03-06-2014 08:56 AM
  3. amcjavelinsst's Avatar
    Best way to go about fixing it when you don't care about the $80 price?
    Pay them $80
    Sent from my GT-N7105T using AC Forums mobile app
    03-06-2014 09:12 AM
  4. dpham00's Avatar
    You may also be able to buy wireless charging system
    03-06-2014 09:31 AM
  5. IAmSixNine's Avatar
    Was it plugged in when you dropped it?
    Its possible a pin was broken off like a unit that came in for repair at my shop a while back. Click image for larger version.
Name:	2013-12-26 14.45.05.jpg
    03-08-2014 03:03 PM
  1. Ok, what are you using the Galaxy Note Pro 12.2 for?
    By Colorado Guy in forum Samsung Galaxy Note Pro 12.2
    Last Post: 10-07-2015, 07:15 AM
  2. [NEW][FREE] Danger UFO : No more flappy bird
    By iliyard in forum Android Games
    Last Post: 04-08-2015, 07:38 PM
  3. Nexus 5: Google Now no longer showing cards
    By DirkBelig in forum Google Nexus 5
    Last Post: 03-04-2015, 09:45 AM
  4. Tap & Pay Functionality on Note 3 Running KitKat?
    By Eddster in forum Verizon Samsung Galaxy Note 3
    Last Post: 08-27-2014, 09:40 PM
  5. charging issue
    By KTKareen in forum Google Nexus 4
    Last Post: 03-12-2014, 11:58 AM
