1. Suertetres's Avatar
    I did some searching and it looks like I may not be the only one with this issue. Just a heads up if any of you are having the same issue.
    I noticed while charging I recently started getting the message "use the original charger for a faster charge" or something to that effect. The phone would also stop charging and start randomly. I'm using the cable and wall plug that came with the phone. So I stopped at Verizon and was told that there is a short in the cable or something is loose and they have been seeing it quite a bit. I was given two options to fix the issue. Take a USB 2.0 cable and be done or call Samsung and file a warranty claim and have a 3.0 cable mailed to me. So I called Samsung, no issue getting a replacement, they emailed me an address label and told me to send mine in and they would mail me another one.
    A few things just didn't sit right with me...Verizon said they weren't given any Samsung 3.0 cables so they offer a 2.0 and tried to convince me it was the same. She called it a USB with HDMI. I asked if she just meant USB 3.0 as I knew it and she told me I was wrong. Oh well...The other part is I have to mail my charger off for them to send me another one. Which will take a few weeks. I am fine using an old usb cable but it just seemed cumbersome. They have the Samsung Experience in most best buy stores, why not incorporate a simple tech support with that? I don't want to get into the Apple vs. Samsung argument but I will say that was great about having an iPhone. If you had an issue, visit a store and it was handled.
    CLIFF NOTES:
    If you are having charging issues. Call Samsung and use an old usb cable until you get a new one. Verizon will only try and give you a 2.0 cable.
    03-07-2014 01:16 AM
  2. Almeuit's Avatar
    That does suck but at least you're getting a free one. It would be nice if they used the stores though.
    Also you're right.. The USB cord is USB 3.0..she was the one in the wrong .
    Sent from my T-Mobile Note 3 using AC Forums.
    03-07-2014 01:27 PM
  1. Moto G: Charging/Vibration Issue
    By Hugo Verastegui in forum Moto G (2013)
    Last Post: 03-27-2014, 03:47 PM
  2. Stock music App issue
    By Ninja1990 in forum Verizon LG G2
    Last Post: 03-12-2014, 03:22 PM
  3. Can't use while charging a low battery
    By eds817 in forum Samsung Galaxy Note Pro 12.2
    Last Post: 03-07-2014, 01:23 PM
  4. Droid MAXX: Temperature issues while charging
    By ::Montgomery:: in forum Motorola Droid MAXX
    Last Post: 03-06-2014, 08:48 PM
  5. HTC One: emoticon and lock screen issues
    By keleraba in forum HTC One M7
    Last Post: 03-06-2014, 08:27 PM
