Results 1 to 14 of 14
    Jalopiejoe's Avatar
    Posts
    Global Posts
    661 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Note 3: Idle time battery useage.
    I left the house this morning with 96% battery and did not use the phone all day. I just checked the battery and it was at 58%.
    Here's what my usage shows!
    I can understand why the clock and weather updates would use power but Clean Master?
    (Maybe I should delete this app?)
    What do you think is going on?
    Sent from my Samsung Galaxy Note 3
    "Size does matter!"
    Attached Thumbnails Attached Thumbnails Note 3: Idle time battery useage.-1394239902362.jpg
  2. #2
    weatherlover1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Idle time battery useage.
    Do you have gsam battery monitor? That will tell you what is keeping your phone awake. I would delete the clean master.
    Posted from my Note 3
  3. #3
    z06mike's Avatar
    Posts
    Global Posts
    2,790 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just delete the app. There really is no need for it unless you have a lot of junk on your phone.
    Sent from my SM-N900V using Tapatalk
  4. #4
    fantom305's Avatar
    Posts
    Global Posts
    574 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would delete clean master and also check the setting on the clock and wheather to make sure it is not updating very often.
  5. #5
    sarkycow's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Note 3: Idle time battery useage.
    I would agree with the other posters - if clean master is using that much of your battery life then delete it.
    I have it but it doesn't even list in my top 10 battery users. My phone has been idle most of today so I thought you would like to see what someone else's looks like.
    Let us know if your battery life gets any better after deletion/using the wake-wake - lock type apps to see what's eating your battery whilst not in use.
    Sarks.
    Sent from my SM-N900V using AC Forums mobile app
    Attached Thumbnails Attached Thumbnails Note 3: Idle time battery useage.-1394261944144.jpg   Note 3: Idle time battery useage.-1394261964198.jpg
  6. #6
    dpham00's Avatar
    Posts
    Global Posts
    24,788 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Close to 4% an hour on idle is way too much. Delete Clean master and perhaps the sense weather too, or at least check the sync settings
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    Jalopiejoe's Avatar
    Posts
    Global Posts
    661 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I deleted Clean Master and backed off the refresh time on the Sense weather and time widget.
    Today's idle time was about the same as yesterday, about 11hrs. & 45 mins.
    Today I went from 95% to 72% battery. I don't know if that's about normal but I hope so!
    Any thoughts or input?
    Thanks! Joe
    "Size does matter!"
    Attached Thumbnails Attached Thumbnails Note 3: Idle time battery useage.-1394329099469.jpg
  8. #8
    FBA
    FBA is offline
    FBA's Avatar
    Banned
    Posts
    Global Posts
    2,465 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Straight idle time only, I see about 1% an hour drain.
  9. #9
    dpham00's Avatar
    Posts
    Global Posts
    24,788 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    what screen on time are you getting?
  10. #10
    clevin's Avatar
    Posts
    Global Posts
    4,166 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Im in the midst of my third battery calibration since last Oct.
    So far its been 18 hrs since charge, 3hr 40min screen on time, 68% left (2 hr movie, rests are web, email, text).
    Overnight, it drained 2% in 8 hrs.
  11. Thread Author  Thread Author    #11
    Jalopiejoe's Avatar
    Posts
    Global Posts
    661 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dpham00 View Post
    I guess I don't know how or where to measure screen on time.
    "Size does matter!"
  12. #12
    clevin's Avatar
    Posts
    Global Posts
    4,166 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Jalopiejoe View Post
    "Size does matter!"
    supposedly, if you check battery usage, then tap the item "screen" on the list, it would tell you how much screen has been on.
    Strangely, after 4.4.2 update, when I was doing the calibration (not sure if its related to kitkat though), the first 2 hrs of video play didn't contribute to the screen on time.
    Jalopiejoe likes this.
  13. #13
    dpham00's Avatar
    Posts
    Global Posts
    24,788 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by clevin View Post
    Yup. Tap on the screen item.
  14. Thread Author  Thread Author    #14
    Jalopiejoe's Avatar
    Posts
    Global Posts
    661 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Found it! Thanks!
    "Size does matter!"
  1. HTC One: TERRIBLE battery drain - worse after KitKat
    By reptar fingers in forum HTC One M7
    Last Post: 05-02-2014, 01:59 PM
  2. Droid MAXX: acceptable / normal battery life?
    By lgbalfa in forum Motorola Droid MAXX
    Last Post: 03-10-2014, 12:05 PM
  3. Moto X: Battery usage
    By eric002 in forum Moto X (2013)
    Last Post: 03-08-2014, 01:46 PM
  4. anyone having trouble with "mediaserver" and battery drain?
    By ljxdaly in forum General News & Discussion
    Last Post: 03-07-2014, 06:36 PM
  5. NFC and battery drain
    By tmarvel in forum HTC One M7
    Last Post: 03-07-2014, 03:30 PM
