1. iain555's Avatar
    Hi guys I've got a uk note 3, and the past month or so the battery life doesn't seem to be that good, read about most guys on here can get over a day without any problem, but for some strange reason I barely make it the full day. The only thing I do is go on Facebook every so often and whatsapp and that's about it. This morning, I unplugged my phone around 9am and went on Facebook for a few mins and it dropped by 2percent.
    Planning to buy a aftermarket battery with a bigger mah to see how it goes, but don't want to change my back cover so I can for the battery. Any suggestions what I should do?
    03-08-2014 07:24 AM
  2. conanheath's Avatar
    Investigate. Signal strength, screen time and an app doing a lot of background services and/or hung up are the three biggest battery hogs I've seen in the forums. Go to your battery stats and see if something is using a lot of battery. Screen will usually be the highest. Also if you select the chart it will bring up signal, awake time, gps and a couple more so you can get an idea of any issues. Search the forums. There are many battery threads with many suggestions.
    anon8380037 and Spencerdl like this.
    03-08-2014 08:50 AM
  3. Amia BooMaster's Avatar
    I'd you have a weak data signal you use more battery in addition to running a little hot. Is your phone ever hot?
    Sent from my BEAST Note 3 using Tapatalk
    03-08-2014 09:09 AM
  4. Jaza85's Avatar
    I rooted my Note 3 for this reason.....now getting on average 17 hours AWAKE time as opposed to the 7-8 hours before rooting.
    Sent from my SM-N9005 using Tapatalk
    03-08-2014 12:18 PM
  5. DrSavant's Avatar
    Install GSAM Battery monitor and Wakelock detector, let your phone run unplugged until a low battery, and see what causes this.
    anon8380037 likes this.
    03-08-2014 12:23 PM
  6. iain555's Avatar
    Just a quick update guys.
    I manage to pick up a genuine Samsung battery last week and so far I've not notice any changes.
    I unplugged the phone at 9 today and at 16.00 it's sitting at 58% surely the there's something draining the battery. Uk Note 3: Battery barely lasts a day-image.jpg
    03-18-2014 01:16 PM
  7. thegame161's Avatar
    I unplugged the phone at 9 today and at 16.00 it's sitting at 58% surely the there's something draining the battery. Click image for larger version.
    What's your screen time?
    03-18-2014 03:27 PM
  8. waz ahmer's Avatar
    I'm sorry to here but I'm on 11 hours of heavy use still have 54% juice left and that's 1/4 brightness level
    03-18-2014 03:41 PM
  9. anon8380037's Avatar
    You can take screenshots of all your settings pages, just wipe over any personal account email and IMEI number.
    03-18-2014 05:35 PM
  10. iain555's Avatar
    Hi guys... I gave up in the end and decided to factory reset my phone. And now the battery is lasting around a day and a half. Very pleased. Thank you guys ever so much
    04-03-2014 10:57 AM
  11. thegame161's Avatar
    You phone dropping 2% when taking it off charge is normal to me.. Mine does that without using it sometimes. Just means if you let it drop to 1% it lasts longer then
    04-06-2014 02:20 AM
  12. thegame161's Avatar
    You think that's bad? it's not if you are using it Abit
    04-06-2014 02:21 AM
  13. Tim Bailey79's Avatar
    Do you mean let it get to 1% before charging it again? As I find the dame problem. (UK NOTE 3)
    04-06-2014 02:51 PM
  14. thegame161's Avatar
    Yeah I've found having it on 1% it lasts the time it round of done at 100% I feel
    04-06-2014 02:53 PM
  15. Borss's Avatar
    Usually clearing the ram and or restarting helps batteries. Android runs an absurd amount of background tasks.
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    04-06-2014 05:04 PM
  1. Note 3: Missing USB tethering? Only got bluetooth option..
    By T0mken in forum Samsung Galaxy Note 3
    Last Post: 10-19-2014, 11:18 AM
  2. Veteran Note owner. 1, 2 and now 3!
    By HothTron in forum Samsung Galaxy Note 3
    Last Post: 03-12-2014, 07:17 PM
  3. Replies: 18
    Last Post: 03-11-2014, 12:49 AM
  4. Note owner 4 life here!
    By HothTron in forum Introductions
    Last Post: 03-10-2014, 01:02 AM
  5. Note 3: Idle time battery useage.
    By Jalopiejoe in forum Samsung Galaxy Note 3
    Last Post: 03-09-2014, 12:15 PM
