A weak battery signal can affect battery life. I did a short test on my Verizon Samsung Galaxy Note 3. First, I ran it about 30 minutes in an okay signal area (~-98dbm, and it drained about 8%. Then I ran it for 14 minutes in a weaker signal area(~-106dbm), and it drained about 7%.
The whole time was mostly using Tapatalk. I took screen shots using Battery Monitor Widget and Gsam to perform my analysis.
I was wondering if anyone else has done a similar analysis and if so, what their findings were. Please also indicate which variant of the Note 3 you have.
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
